Windows 7: Windows 7 64bit sound problem on Asus p7p55d-evo
18 Apr 2013   #1
eaglepi
Windows 7 ultimate SP1
Hi Guys and gals,
A while back about a year ago I updated my audio drivers once I was done I had Via HD Vdeck as my sound properties panel ( for a lack of what it is really called ) Tonight I was messing around with it to see if I could find someplace on it to adjust my 2 speaker balance from left to right or however it needed to be adjusted. back then I had this panel to control my sounds but nothing I could find for balance.
I went to Asus's website and found a newer driver than I had installed so I installed it, it didn't install and I tried it 3 times. finally I deleted it from my device manager and rebooted and windows found a driver that works fine, by "fine" I mean I can play sounds from my speakers and I can record from my mic.
However I would like the ability to make some adjustments like left to right balance. The task bar icon only shows a volume slider and for some reason a slider for each program open at that time.
Is there a basic sound mixer that works with Windows 7 64 bit, free would be nice
Thanks for any replies
18 Apr 2013   #2
fireberd
In most (all that I've seen) the vendor's drivers (in this case ASUS) is the preferred driver. If the Via did not install there is some other problem or you downloaded the incorrect version. Check the ASUS site, for your specific motherboard, again as I think there are several versions of the driver available. Try them all to see one will give you what you want.
I have a newer ASUS motherboard but it has RealTek on it so I can't compare.
Some media players have EQ and possibly Left/Right balance controls. There is no 3rd party application that I know of since if it is available its a function of the correct sound driver.
Windows will install the "HD Audio Codec" which is a generic basic function sound driver. It will give you sound but not much more. It doesn't include the Stereo Mix (System Mixer) which is needed to record streaming audio from the internet and missing other enhancements.
18 Apr 2013   #3
eaglepi
Thanks for your help that is what I thought also, the problem is when I installed it a year ago it didn't have the balance slider to adjust the left right balance.
18 Apr 2013   #4
fireberd
Some do not have the left/right balance adjustment. However, my RealTek does.
18 Apr 2013   #5
eaglepi
Thanks again but I did find a way in win 7 to adjust the balance from left to right
18 Apr 2013   #6
fireberd
Cool, if its fixed mark the thread as solved.
18 Apr 2013   #7
eaglepi
Not sure how to make it solved IT's SOLVED
18 Apr 2013   #8
fireberd
There should be a Solved button on you post
CPU Heat Warning Tone: Where is it coming from? (I5 750 & Asus P7P55D)
I've been playing with overclocking my Intel i5 750 on a Asus P7P55D Pro. At one point today I was running temps up around 63c while running Prime and I started to hear a constant, piercing tone, like some kind of warning. It was not coming from the system audio because it continued when I...
Hardware & Devices
16GB or Ram to be employed on ASUS P7P55D Mother board
I have loaded 16GB of Corsair 1333 ram onto my system's P7P55D Rev 1.xx MB. I am running Windows 7 64 Bit OS. The OS sees the full load, but it will only use 8GB as ram. How do I effect the full 16GB of useful Ram? Bio's update? Is this a board limitation where a later variant such as the LE...
Hardware & Devices
Best RAM for Asus Motherboard P7P55D
Hi all, Any idea what's the best value RAM for the above board? It's been a while and a recent game seems to have boned my RAM (or just pointed out the fact it was already boned) Memtests are failing and the game in question keeps BSOD'ing and crashing to desktop. All was fine before...
Hardware & Devices
Asus P7P55D-E motherboard...
Buying a new motherboard from Asus might be a gamble, at least with the P75P55D-E model. Asus website list the motherboards' features at their web site: ASUSTeK Computer Inc. Here are some of the features: Marvell® SATA 6Gb/s controller: - 2 x SATA 6.0 Gb/s ports (gray)
Hardware & Devices
Asus P7P55D-E Pro, couple questions
good morning, i had a few questions i would like to resolve about my motherboard... 1. i have a sataIII 6gb/s hard drive and a sata optical drive, i have the optical drive plugged into the intel controller, sata port #4, and it shows up in my bios under the main screen and i can boot from...
Hardware & Devices
Over clocking asus p7p55d motherboard
Hi, I have just built a new system and am running windows 7 x64. I have 1600MHz memory but my asus p7p55d motherboard is running at a default 1067MHz. When I first put everything together last week I tried adjusting just one setting in the bios that controls the memory speed. I boosted it...
Hardware & Devices
