Solved Need Help With no sound in windows 7 home premiun 64 bit
rinkkitu
5:55 PM
Yesterday i download one video file and when i started playing it prompt to update codec and i agreed to update codec and now no sound in my system.
1) i have checked my all services are working.
2)all drivers are fine.
3)it is not mute
4)tried to restore but still no luck.
5) in event manager its shows
Event filter with query "SELECT * FROM __InstanceModificationEvent WITHIN 60 WHERE TargetInstance ISA "Win32_Processor" AND TargetInstance.LoadPercentage > 99" could not be reactivated in namespace "//./root/CIMV2" because of error 0x80041003. Events cannot be delivered through this filter until the problem is corrected.
and when i plug my head phone in computer i hear buzz sound please help.
i have tried everything i know but no luck please help me out what can do to fix this NO SOUND issue
thanks in advance.
Uninstall the codec ? or System restore to before you installed the codec
Or install something like k-lite mega codec pack, it performs a scan and repair of codecs at the end of the install
Windows 7 SP1 x64Phenom II 965 X4 C3 BE @4GHz4GB G-Skill RipJawsX 2133AMD Sapphire 7870 OC GHz Edition @ 1300MHz
Windows 7 SP1 x64
Crosshair V Formula
SupremeFX X-Fi 2
23" S231HL
2TB Seagate ST200DM
2 x 160GB
Corsair TX950W
Coolermaster HAF922
Tuniq Tower 120 Extreme - Arctic Silver 5
Logitech Wireless
Logitech Wireless
ESET NOD32
Thanks for reply
where can i get k-lite mega codec pack
Windows 7 SP1 x64
Crosshair V Formula
SupremeFX X-Fi 2
23" S231HL
2TB Seagate ST200DM
2 x 160GB
Corsair TX950W
Coolermaster HAF922
Logitech Wireless
Logitech Wireless
ESET NOD32
i downloaded that codec pack and installed it but still i am having same problem , even i restarted me laptop as well
You may have downloaded some malware with the 'update codec' message ....
scan your machine with ESET OnlineScan
  1. Hold down Control and click on the following link to open ESET OnlineScan in a new window.
    ESET OnlineScan
  2. Click the
    button.
  3. For alternate browsers only: (Microsoft Internet Explorer users can skip these steps)
    1. Click on
      to download the ESET Smart Installer. Save it to your desktop.
    2. Double click on the
      icon on your desktop.
  4. Check
  5. Click the
    button.
  6. Accept any security warnings from your browser.
  7. Check
  8. Push the Start button.
  9. ESET will then download updates for itself, install itself, and begin scanning your computer. Please be patient as this can take some time.
  10. When the scan completes, push
  11. Push
    , and save the file to your desktop using a unique name, such as ESETScan. Include the contents of this report in your next reply.
  12. Push the
    button.
  13. Push
Windows 7 Ultimate 32bit SP1
INTEL/D975XBX2
ATI Radeon HD 2600 Pro
Samsung SyncMaster 914v
1280 x 1024
One is not connected
Rocketfish 700 W
G.Skill Gigabyte Chassis
Standard PS/2 Keyboard
Microsoft PS/2 Mouse
DSL
Avira Internet Security
IE 11
ATI HDMI Audio
Try the malware advise above, if that fails I would try a system restore
Windows 7 SP1 x64
Crosshair V Formula
SupremeFX X-Fi 2
23" S231HL
2TB Seagate ST200DM
2 x 160GB
Corsair TX950W
Coolermaster HAF922
Logitech Wireless
Logitech Wireless
ESET NOD32
thank you very much buddy, its works
