Volume mixer issue / sound control
  1. Posts : 2
    Hello guys,
    I searched the forum for common problems but unfortunately I could not find any useful information for this issue.
    I hope you can assist me as the Windows 7 volume mixer is freaking me out and I cant seem to find a way out with this...
    I run Windows 7 on a Dell Inspiron 6400 and I use the volume buttons on front a lot to increase/decrease/mute the sounds... however this feature is not working with Windows 7 or maybe I have not fixed the correct settings.
    Also I have a Logitech MX610 mouse with volume buttons on it that don`t work as well.
    Here is a screenshot of the volume mixer.. I`m not sure if that`s helpful..
    Any help will be much appreciated.
    Thanks in advance guys
    Attached Thumbnails Attached Thumbnails Volume mixer issue / sound control-volume-mixer.jpg
  2. Posts : 6,879
    Win 7 Ultimate x64
    viachy, welcome to the forums.
    For the volume buttons on the laptop, is there or did you install a driver for it? It may or may not be needed, but from the sounds of it, it is.
    For the mouse, what version of Setpoint do you have installed? The latest is 4.80 (for Vista, but works well in 7),
    Logitech > Support + Downloads > Downloads > Mice > MXâ„¢610 Laser Cordless Mouse
  3. Posts : 2
    Тhanks for the welcome stormy,
    The link that you gave me with the driver worked and fixed my problem
  4. Posts : 1
    windows 7
    Hi all,
    I have the same problem on my inspiron 6400
    The sound works but if i change the volume a couple of times
    my taskbar freezes(exept start button).
    If i click on the taskbar i hear the same sound when you change volume.
    PING PING PING
    very annoing
    And i have to reboot
    Any idea's?
    p.s. i don't have a mouse, with sound adjustment
    Thnx
    BBlaze (from holland)
