Windows 7: Setting up "What u Hear" using Rocketfish 7.1 on Win7 32bit
22 Apr 2013   #1
arossi10
Windows 7 32bit
Hi, I have upgraded my XP to Windows 7 32bit. I have been trying to record from the net using a Rocketfish 7.1 sound board, but it will not allow to setup my source as What U Hear. I have tried to use the instructions by Corpsecrank written in 2009. My windows do not display the Disable Devices or Disconnected Devices. Is there something missing from Rocketfish install? Is there some additional later information for Windows 7 sound setup. It does display Rocketfish 7.1 Microphone, Line In, Auxiliary and my Webcam.
22 Apr 2013   #2
stormy13
Microsoft MVP
Win 7 Ultimate x64
arossi10 welcome to the Seven Forums.
Did you remember to install the driver for it?
Rocketfish
The one they have is for Vista but it should work in Windows 7 no problem.
22 Apr 2013   #3
arossi10
Windows 7 32bit
Hi, Yes I installed the latest drivers for it which was described as Windows 7 compatible. It was a good install I got the complete control panel with it. I might try to go back and try to use the on board sound section.Which Audilgy
Art
23 Apr 2013   #4
stormy13
Microsoft MVP
Win 7 Ultimate x64
Unfortunately it looks like you may be out of luck,
Creative Worldwide Support
Quote:
Note: The following sound cards do not support What-U-Hear in Windows 7 and Windows 8:
  • X-Fi Xtreme Audio
  • PCI Express X-Fi Xtreme Audio
  • Sound Blaster Audigy Value/SE
* The bundled software must be installed for Stereo Mix - What "U" Hear feature to be available.
and your card despite saying Rocketfish on the box, is nothing more than a Creative Xtreme Audio.
24 Apr 2013   #5
arossi10
Windows 7 32bit
Hi, Can you recommend any sound cards that will support What U Hear on Windows 7 32 bit.
Art
24 Apr 2013   #6
Faladu
Windows 7 Ultimate Retail Box (64-bit installed) + Service Pack 1
A possible alternative:
Audio/Video Recorder, Editor, Converter. Capture streaming video and audio.
Its main feature is that it installs a "driver" which intercepts "what you hear" and routes it to the recorder. It does NOT depend on the feature being implemented by the driver for your current sound card, etc.
24 Apr 2013   #7
Faladu
I just used this tutorial and managed to get my USB mic heard & recordable in addition to anything else playing on my system through the headphones.
Recording Using Vista or Windows 7 | SingSnap Karaoke
24 Apr 2013   #8
chev65
Quote   Quote: Originally Posted by arossi10 View Post
Art
I tried all the different sound cards including the Creative X-Fi, and Auzentech Prelude and the Asus Xonar D2X series which was the only one that worked right with the What U Hear feature.
Audigy 2 echo and low volume in "What You Hear" Windows 7 64 bit
Hi, I have 2 systems and the other is listed in my profile so here are this system's specs. Intel e7200 cpu Gigabyte EP43-UD3L Motherboard 4 gigs of ram OCZ 120 gigabiyte SSD for OS Seagate 1TB 7200rpm storage drive Nvidia 9800 GT
Stereo Mixer "What U Hear" Suddenly Stopped Working
I realize the title happens frequently in general. I myself have had to go in and restore the device countless times on reboot. That's not the issue (default device, device enabled, etc). For some mysterious reason, my What U Hear is malfunctioning and picking up absolutely nothing as of last...
"" instead "\" when System locale is setting to Japanese
Well, its my first post here and my english is not good, Hi all! :p I've installed win7 ultimate 64bit yesterday and Iam having a annoying problem when System locale is setting to Japanese: The standard "\" character in shortcut dialog box, for example was replaced with yen symbol () Windows...
General Discussion
Win7 "workstation" to WinXP "server" file copy FAIL
This is driving me bonkers and I have almost no hair left. I really hope someone can help. When I attempt to copy or move a file or folder from my Win7 box to my WinXP (SP3) media server, the operation nearly always fails. Take, for example, my trying to copy the VLC Media Player folder (704...
Network & Sharing
Windows 7 Can't record "What you Hear"
Hi, my first thread here. I have searched many forums and webpages looking for a solution for my problem. I just bought a Sony Vaio VGN-NW26M Laptop for Recording Music and Video Editing. My audio card says its a RealTek High definition. I just can't seem to find any Line-In or Audio Mix. I...
upgrade win7 32bit to win7 64bit "in place" ?
Is it possible to upgrade in place from win7 32bit to win7 64bit. Is it better to do a clean new 64bit install? thank-you!
Installation & Setup
