Asus M4N68T-M NO AUDIO OUTPUT DEVICE IS INSTALLED
  1. Posts : 8
    windwos 7 professional,windows 8 professional
    I HAVE Asus M4N68T-M I AM USING WINDOWS 7 I AM NOT GETTING SOUND I HAVE DONE EVERY TROUBLE I AM UNABLE TO FIND PROBLEM CAN SOME ONE HELP ME I HAVE UPLOAD PROBLEM PICS ON PHOTO BUCKET No Audio Output Device Is Installed Photos by azheruddin | Photobucket
    When you instaled, did you install the ASUS motherboard chipset drivers and then the ASUS sound driver? If not, give that a try.
    Also, is the sound enabled in the BIOS? check that first before installing the motherboard chipset drivers and the ASUS sound driver. That may be the problem as Windows, during the install, if the sound module is detected will at least install the generic, basic function, HD Audio Codec and from what I see that was not installed.
    What is the model number of the ASUS motherboard? That would help, too.
  3. Posts : 8
    Installed asus chipset,sound every driver but no sound
    my mother board is ASUS - M4N68T-M i have installed drivers but no sound i think my inbuild sound card has been damaged
  4. Posts : 8,135
    Have you checked the BIOS to make sure the integrated audio (in built) is enabled. If it were disabled in the BIOS you wouldn't be able to install drivers and/or use it.
  5. Posts : 8
    no sound bios at startup
    i have checked bios on startup i didnt find sound bios there
  6. Posts : 8,135
    Its there, its listed as "Azalia Audio".
  7. Posts : 8
    Not listed
    it was not listed Azalia Audio
  8. Posts : 8
    Audio Manufacturer
    my sound card is VIAVT1708S SUPPORT 8 CHANNEL HIGH DEFINATION AUDIO
    VIA Vinyl
  9. Posts : 8,135
    If its not listed you need to contact ASUS. It was listed in the ASUS manual, BIOS section, for your model motherboard.
  10. Posts : 8
    Thanks Jack i will contact Asus for the problem
