No Sound on HDMI out
Page 1 of 3 123 LastLast
  1. Posts : 7
    windows 7 build7600
    hey there
    first sry for my bad english
    after searching google all day and upgrade my soundcard,motherboard and graphic drivers still i cant fixed my sound problem. Still i cant hear anything on Palit 9800 Hdmi out. i change my default playback device to "Realtek Digital Output" but still no sound on hdmi. when i use my pc speaker everything is working very good but i want to watch my MKV s on my tv.
    i was upgrade from windows xp and when i using xp my system was worked very good
    My Pc Spec
    gigabyte p35c ds3r mobo with Realtek alc889
    palit 9800gt
    Windows 7 build 7600 64bit
    My drivers
    Realtek R229 "vista_win7_r229.exe"
    Nvidia 190.38 "190.38_desktop_win7_winvista_64bit_english_whql"
    My AV Reciever
    Philips DFR 9000 "its support dts thx and other things"
    How can i fix this problem ??
  2. Posts : 4,573
    Only some video cards carry audio over the HDMI port. The RealTek hi-def audio port is NOT on the HDMI cable. Coonect the RealTek digitial audio port directly to your TV/system.
  3. Posts : 6,879
    Win 7 Ultimate x64
    You get a cable like this with your video card,
    If not contact Palit and ask them about getting one, as no Nvidia card can do audio over HDMI without one of those cables going from the sound card to the video card.
    Edit: And here is how you do it,
    http://www.overclock.net/nvidia/4411...ml#post5305349
  4. Posts : 7
    windows 7 build7600
    thx for help guys but i have that cable and it works perfectly in windows xp . when i was upgrade to windows 7 my problems start. i m talking about working system guys still same cable still same card i make same connection like this only chage is windows 7. but now i cant transfer sound on hdmi port.
  5. Posts : 6,879
    Win 7 Ultimate x64
    You have it set to SPDIF/digital out in the Realtek controls as well as the Windows one?
  6. Posts : 7
    windows 7 build7600
    thx for fast reply stormy
    if you change one (in windows control or in realtek control panel) other one is automatically change but yes i did and check both of them again still no sound.
  7. Posts : 419
    Windows 7 Build 7600 64bit/Ubuntu/Leopard
    which version...200
  8. Posts : 7
    windows 7 build7600
    7Dreams said:
    which version...200
    i dont understand what r u asking for but you can check my first post for drivers and windows7 version
  9. Posts : 623
    vista x64/ win 7 x64
    if you have a digital input on your amp, try first if you can get sound using a spdif cable.
    I myself don't use the hdmi for sound. I plug the spdif to my surround amp. And it worked even with a v186 Realtek driver.
  10. Posts : 7
    windows 7 build7600
    my system was work very good in xp and now why i need a new cable now :S if i transfer everything in one cable why i use 2 cable... and i think you cant give me guarantee for spdif is work when i will buy a new cable because they r same.. i think nothing is change taking out on mobo jumper or taking out from back of mobo spdif..
