Windows 7: Realtek HD Audio volume is a little too quiet, Help in increasing nois
05 May 2013   #11
Dude
Windows 10 Pro X64
This thread might help you
06 May 2013   #12
zasheh
Windows 7 Home Premium 64Bit
Oh hey i found something interesting
On windows Media Player it plays actually Quite damn loud...Yet on firefox and google chrome it's quiet and where the problem is coming from?
Is this possibly something to do with them now?
06 May 2013   #13
Dude
Windows 10 Pro X64
Could be, right click your speaker icon and select open volume mixer to make sure they are all turned up.
08 May 2013   #14
zasheh
Quote   Quote: Originally Posted by Dude View Post
Maxxed out, firefox still quietish
Realtek high definition audio max volume is about 50% than before,help
hello. At some point I chose to reinstall Windows. I installed and updated all the drivers, etc and set the speakers up the same way as before. Only this time the audio was around 50% of the volume it was previously with volume up full. I reinstalled all audio drivers 5 times already, dont know...
Realtek® ALC887 8-Channel High Definition Audio Very Quiet
Hey. I have the Logitech LS21 speakers. I know they are cheap speakers. When I first set them up, I was actually very impressed with the volume and quality of the sound and bass. It was enough to fill my modest sized room with loud clear sound and rich base when listening to music. I had them...
Realtek HD Audio Very Very Low Volume - Mb: ASRock Z77Extreme3
Hello, I'm having an issue with my audio, the problem is that my volume is extremely low even with maxed out settings in realtek audio manager and speakers turned all the way up. I have tried installing and reinstalling drivers from MB drivers and directly from Realtek to no avail. ...
Realtek HD Audio Very low Volume and Variable
Hi, Having a bit of an issue configuring my Realtek Audio Drivers on my computer. Originally I had a setup using an external audio interface (Desktop Konnekt 6), but I recently split my system apart so I have to start using the onboard audio on this computer once again. Originally I had the...
After i connected my speakers to my laptop(they were connected before to my computer) i have noticed a small difference in volume. On my laptop the volume is lower than on pc and i guess is because of the sound card and driver but i have everything at 100% . Could this difference of volume be from...
Soft Recording volume with Blue Yeti, increasing volume distorts audio
So I have a Blue Yeti, and I'm an online animator/voice actor. Whenever I record audio on my Blue Yeti (OR any other mic) I record about 4-6 inches from the mic, and turn the gain down enough that the audio doesn't peak as I yell or whatever. This is what you're supposed to do if you don't want...
