Windows 7: Realtek HD - Low Volume Fix
31 Aug 2015   #11
aldaaime78
Windows 7 Ultimate x6
Late thanks!!!The topic is also useful for me !!! etui sony xperia C5 ultra housse sony xperia C5 ultra
12 Sep 2015   #12
miahiv
Quote   Quote: Originally Posted by styr View Post
1. Open realtek hd audio manager from taskbar
2. Under analog you should have inputs, right click the green input (depends if you have it plugged on front or back) and choose connector retasking
3. Check the option "headphone"
thank you!:d
24 Oct 2015   #13
Tanathip
Windows 8 Single Language x64
Found another method
I've just found another method. Simply go to Realtek HD Audio Manager, go to Sound effects and check the box: Loudness Equalization. This fixed the issue for me
25 Aug 2016   #14
markaz
Thank you
Quote   Quote: Originally Posted by Styr View Post
Hello there,
Instead of replying to older posts i'll just create another one. I've seen few people having issues with low volume with Realtek HD, I was one of them. My sound "system" is just pair of headphones so 100% volume was not enough for me. So after few days of messing about I found an solution:
1. Open Realtek HD Audio Manager from taskbar
2. Under ANALOG you should have inputs, right click the green input (Depends if you have it plugged on front or back) and choose Connector Retasking
3. Check the option "Headphone"
Now the volume should be louder.
What also helps is if you check Loudness Equalization under the sound effects tab in Realtek HD Audio Manager or Speakers Properties.
I hope this thread helped.
Wasn't looking for any miracles, but 6-8 straight hours of power watching Netflix using headphones with my PC made for some sore ears. My wife had some cheapie earbuds that came with her portable CD player so I figured what the heck. Plugged them into the front analog panel and they worked, but volume extremely low. Did the steps you outlined and bingo. So loud I had to actually turn the volume down. Checking the Loudness Equalization probably kicked the volume up 50% by itself. Thanks for the post.
Search this Thread:
Advanced Search
Low volume/sound limiter (realtek)
Realtek ALC662 + Windows 7 here. I've been everywhere, from BIOS, to new, old drivers, equalizing, desequalizing, been to every menu on sound I could find. And certainly deactivated that "conversation setting" supposed to bring your volume down when in calls. Yet, my sound is terrible. I'm...
Realtek high definition audio max volume is about 50% than before,help
hello. At some point I chose to reinstall Windows. I installed and updated all the drivers, etc and set the speakers up the same way as before. Only this time the audio was around 50% of the volume it was previously with volume up full. I reinstalled all audio drivers 5 times already, dont know...
Realtek HD Audio Very low Volume and Variable
Hi, Having a bit of an issue configuring my Realtek Audio Drivers on my computer. Originally I had a setup using an external audio interface (Desktop Konnekt 6), but I recently split my system apart so I have to start using the onboard audio on this computer once again. Originally I had the...
RealTek ALC888 - Low volume issue
First off here is what I am using Hardware: Windows 7 x64 RealTek ALC888 -> R2.70 drivers for Windows 7 64 bit. Headphones: Creative Fatal1ty Audio settings: Loudness Equalization enabled, 16bit 48000 Hz DVD Quality.
Realtek HD Audio volume
After i connected my speakers to my laptop(they were connected before to my computer) i have noticed a small difference in volume. On my laptop the volume is lower than on pc and i guess is because of the sound card and driver but i have everything at 100% . Could this difference of volume be from...
SRS Volume Problem on Realtek HD
Hello I have windows 7 ultimate 32 bit and i have installed SRS HD Audio Lab on my reltek but there is a sound problem The volume comes low.......:( plz help
