Realtek HD - Low Volume Fix
Styr
3:32 PM
Hello there,
Instead of replying to older posts i'll just create another one. I've seen few people having issues with low volume with Realtek HD, I was one of them. My sound "system" is just pair of headphones so 100% volume was not enough for me. So after few days of messing about I found an solution:
1. Open Realtek HD Audio Manager from taskbar
2. Under ANALOG you should have inputs, right click the green input (Depends if you have it plugged on front or back) and choose Connector Retasking
3. Check the option "Headphone"
Now the volume should be louder.
What also helps is if you check Loudness Equalization under the sound effects tab in Realtek HD Audio Manager or Speakers Properties.
I hope this thread helped.
Windows 7 x64
Windows 7 x64
Good Info. Except not all RealTek's have the HD Audio Manager and those that do there are may variations in the HD Audio Manager from the various PC and Motherboard Vendor's. Some have all the options like yours and some do not.
I recently worked a problem for a Laptop user and the Laptop Manufacturer didn't provide any RealTek audio manager (the generic drivers from RealTek did not either).
My Own Build
Intel i7 6700K
ASUS ROG Maximus VIII Hero
16GB Corsair Dominator
Intel CPU Graphics
RealTek
27" Dell S2719dgf
2560X1440
2 TB drive for backup
EVGA Supernova 750G2
BeQuiet Silent Base 600
Deepcool Captain 120EX
Microsoft Wireless 2000
Microsoft wireless
100 MB/sec (Cable)
Edge/Firefox
there's one more way to make it a little bit louder.
in the same realtek hd audio manager, switch to sound effects, press the equalizer icon (square with small dots inside) to switch to graphic equalizer mode, then drive every slider all the way up. this should make it a little bit louder.
windows 7 ultimate x64intel i5 33308 gbgts 450
custom build
intel i5 3330
8 gb
gts 450
intel hd ;_;
avg
firefox
When I open up the Realtek HD Audio Manager I dont have the green input option. I only have a black circle under the ANALOG. When I right click it, nothing happens. I have updated my Realtek diver to the latest version, how do I fix this?
imgur: the simple image sharer (it looks like this, it is in Dutch, but that doesnt really matter)
Windows 7 Home Premium 64 bit4.00 gig
Acer Aspire M3-581TG
4.00 gig
Every motherboard I've had since 2004 had RealTek audio that was too quiet, especially for recording "what you hear".
The only solution that worked for me was to buy and install a sound card and disable RealTek onboard sound.
Win10 Pro 64-bitAMD Ryzen 7 3800X32 GB Kingston DDR4-2666MSI nVidia GT 710 (2GB)
Self-Built
Win10 Pro 64-bit
AMD Ryzen 7 3800X
Gigabyte X570 UD
Creative Audigy FX 5.1
ViewSonic VG2439Smh 24"
3xWD1TB; 1xSeagate 1TB... all spinning rust
EVGA 100-W1-0500-KR (500w)
SilverStone PS10 (modified)
CPU:AMD Wraith Prism. Case:3x Noctua 120mm
Compaq Professional PS/2
Microsoft Basic Optical Mouse 2.0
Fiber 1Gbit/sec down/up
Avast Free
FF, Chrome
2x LG GH24NSC0 DVD burners, Mackie CR3 monitor speakers
sometimes it's just not possible though. in my case, i only have 2 pci slots. one is covered by the gpu, another is so close to it that anything plugged into it covers up the gpu's fan. i tried using my old audigy, but it made the gpu overheat a lot.
getting an usb headphone set helped, the sound gets very loud when it needs to now.
custom build
intel i5 3330
8 gb
gts 450
intel hd ;_;
avg
firefox
(i made this acount just to post this)
Dude thank you so so much. When i was on windows 7 i had this option enabled somehow and enjoyed the loud music and now when i installed windows 10 and it drove me crazy why my sound volume was so low, and i kept reinstalling drivers with no result. after 1 week of banging my head in the wall i finally found your post, again THANK YOU SO MUCH :)
Windows 10 Enterprise x64
Hey Zoumer, just wanted to say I just googled this volume fix and thanks to your post about windows 10 I'm pretty sure it helped me find this and the fix worked great. So thanks for bumping this up, you saved me a low volume headache.
Windows 104690K @ 4 Ghz16 GB DDR3GTX 970 OC Edition
Windows 10
4690K @ 4 Ghz
MSI
16 GB DDR3
GTX 970 OC Edition
Lots
Same here! Only I have a Dell. I had to go to "Dell Audio" instead to do this.
Windows 10
Windows 10
Same here, I formatted my PC and my AUDIO went low a little bit, and this fixed it, thank you very much!
windows 8.1 64 bits
windows 8.1 64 bits
1. Open realtek hd audio manager from taskbar
2. Under analog you should have inputs, right click the green input (depends if you have it plugged on front or back) and choose connector retasking
3. Check the option "headphone"
thank you!:):):):):):):):):):):):):):):):d
Windows 7 Ultimate x64Intel core2 duo
custom build
Intel core2 duo
Gigabyte GA-EP43-DS3
Found another method
I've just found another method. Simply go to Realtek HD Audio Manager, go to Sound effects and check the box: Loudness Equalization. This fixed the issue for me :)
Windows 8 Single Language x64Intel Core i7-4710HQnVidia GeForce 870M
MSI
nVidia GeForce 870M
Avast! Free Antivirus
Thank you
Hello there,
Wasn't looking for any miracles, but 6-8 straight hours of power watching Netflix using headphones with my PC made for some sore ears. My wife had some cheapie earbuds that came with her portable CD player so I figured what the heck. Plugged them into the front analog panel and they worked, but volume extremely low. Did the steps you outlined and bingo. So loud I had to actually turn the volume down. Checking the Loudness Equalization probably kicked the volume up 50% by itself. Thanks for the post.
Windows 7 Home Premium x64AMD A6-6400K APU8.0GB DDR3-1600Radeon Onboard Graphics
AMD A6-6400K APU
Gigabyte F2A88XM-D3H
8.0GB DDR3-1600
Realtek High Def
Acer K242HQL
Samsung 850 EVO SSD 250GB
Corsair 430W
Silverstone PS-08
Enermax fans (120mm-intake, 80mm-exhaust)
Logitech K360
Logitech M305 Cordless Optical
Download 60.19Mbps Upload 6.71Mbps
AVG
Iron Version 51.0.2700.0 (64-bit)
...Except not all RealTek's have the HD Audio Manager
I solved the problem of low volume on my ThinkPad T430 by simply uninstalling the Realtek driver. Windows 7 then defaulted to the Windows sound manager which I find provides better sound quality, with more controls, and plenty of volume when Loudness Equalization and Bass Boost are turned on: right-click speaker icon in Taskbar > Playback devices > highlight the device in use > click Enhancements tab > select Bass Boost and Loudness Equalization.
Win 7 Pro 64 bitAMD Phenom 98504 GBnvidia geforce 620
custom build
Win 7 Pro 64 bit
AMD Phenom 9850
BioStar 790 A2+
nvidia geforce 620
WD 640 GB + 160 GB SATA 3
MS
FF
This post is saving lives since 2013, I registered here just to say ; Thank you sir !
Microsoft
Microsoft
