Sound
Try to install sound driver on note pc and it give me a code 10 ,how to fix it i try almost ever thing need help
Try reading this fix for Code 10...
WindowsAnswers.net - How to Fix Code 10 Error
Post back if you need more help.
THW
Are you using the Dell supplied sound driver? If not that is the preferred (and many times the only one that will work or work properly on a Dell).
I am using a toshiba lap top and I try to down load driver but pc can't install high definition audio controller tell me code 10 why
Please post the PC model so I can research what actual hardware is in the PC. Your "My System Specs" lists an Alienware.
Code 10 can be wrong drivers, the device is disabled in the BIOS, a defective sound chip, etc.
Satellite l505d- ls5002 system unit
Where are you getting the Code 10? In the Device Manager or does it tell you that when you try to install?
What is listed in the Device Manager for sound?
Have you verified its still enabled in the BIOS?
