Windows 7: Audio Jack not working, but USB Audio is.
12 May 2013   #11
wildilwh09
You sir a genius thank you. What I did to fix was download my motherboards sound driver as I had my windows sound driver installed. Just as "Dude" told me to.
Thanks, greatly appreciated. Lee.
12 May 2013   #12
Dude
Windows 10 Pro X64
Glad it worked Lee It always is better to use your motherboards driver for on board sound.
Front Audio Jack, right sided speakers/cup not working
Hello, I'm Artekis. A year ago, sevenforums helped solved my BSOD problem! Now I'm back for help on audio problems. I recently noticed that the front audio ports of my Windows 7 PC do not work properly. I plugged in both speakers and my headset, and the right side of the speakers do not work as...
Front jack not working for Realtek HD Audio on Windows 7
Hi all, I've just installed Windows 7 and was very happy to see all the hardware working, even my Realtek HD Audio sound card, except the front jacks. On windows XP I could solve this by with the Sound Manager that comes with the realtek drivers, and select the "Disable front panel jack...
Audio jack not working properly
Since yesterday my laptop has been doing something very weird. I can't get any audio through the headphone jack. The laptop's speakers work fine. When I plug in the headphones then the sound continues to come out of the speakers. When I check the sound devices it shows that the headphones are...
Rear audio jack not working properly
I got a brand new computer. Motherboard is a Gigabyte GA-78LMT-S2P. Operating system is Windows 7 Professional 32-bit. Brought it home, it installed a .net update and restarted and since then, I've had the infamous RealTek pop-up problem. Keeps telling me something is plugged in then unplugged...
Front I/O Audio Jack not working.
Hello, Last month I built my own computer. I am having a problem with my Front I/O audio jacks. - Headset is Beats by Dr. Dre Solo HD - I have went into BIOS and enabled my Front I/O - My front I/O is properly connected to my Motherboard - My driver is Realtek HD R267 (Newest driver)
No audio from rear jack & no hdmi audio
hi guys pretty new here so take it easy plz (lol) i have 2 problems regarding audio. 1. when i upgraded my pc i added a okish motherboard but i wanted sound from my front panel so i took the jumper cap off the prongs for audio but now i have added some desktop speakers and want to plug them...
Graphic Cards
