Win 7 high definition audio device problem
  1. Posts : 34
    Windows Ultimate 64bit
    Hi everyone i have big problem..... so i have an high definition audio bus and i want to uninstall it but i cant when i uninstalled then rebooted my computer windows automaticly installs them again so i cant install other sound drivers bicause that "high definition audio bus" keeps installing it.
    I was in the start > change device installation settings > and it dont give any help it still installing that driver again and again my computer is Windows 7 Ultimate 64bit please if somebody can help!
  2. Posts : 13,576
    I had the same problem with my Epson printer. Even changing auto driver settings didn`t help.
    Solution: Uninstalled the drivers, then re installed the drivers and software I wanted, then rebooted windows and it didn`t need to install anything else.
    Don`t reboot just uninstall, install, THEN reboot, see what happens.
    You do have the drivers you want to install ready to go, correct ?
  3. Posts : 5,915
    Windows 10 Pro X64
    Try the audio driver on this page
    Asrock
  4. Posts : 34
    thats the problem when i uninstall the hd audio and install other drivers then reboot my computer the drivers i installed is not there but the old drivers is installing not new ones
  5. Posts : 5,915
    Windows 10 Pro X64
    Go to device manager, go to your audio device in sound video and game contollers., right click choose properties select driver tab..select update driver, choose browse my computer, install the one form the Asrock site in my earlier post when dowlnoaded and saved to a location you remember
    This is what AddRam was saying
  6. Posts : 34
    [QUOTE=Dude;2395770]Go to device manager, go to your audio device in sound video and game contollers., right click choose properties select driver tab..select update driver, choose browse my computer, install the one form the Asrock site in my earlier post when dowlnoaded and saved to a location you remember
    This is what AddRam was saying[/QUOT
    YES thank you very much now i can play my games with sound besides
    i not very good on english language bicause i am from lithuania
  7. Posts : 1
    Windows 7 Professional 64bit.
    hey guys, i got an issue. both speaker and headphone work, but the thing is when the speaker is working and i plug in my earphones to the headphone jack, no sound. unless i enable it as default device then the headphones work, but then the speaker stops even if i remove my earphones from the jack.
