No Audio Output Device Installed/No sound card found
Hello all,
I hope you could help me with my problem.
Recently, I got problem with my PC, just all of a sudden, it stopped booting and later on the HDD got wiped and I have no saved data. So I reinstalled using USB, before I was running Windows XP, but I prefer to install Windows 7. The thing is, I don't have sound anymore.
Here's everything you need, this is my DxDiag.txt file
I don't have Sounds, Video and Game Controller tab in Device Manager.Code:------------------ System Information ------------------ Operating System: Windows 7 Professional 32-bit (6.1, Build 7601) Service Pack 1 (7601.win7sp1_gdr.130318-1533) Language: English (Regional Setting: English) System Manufacturer: AWARD_ System Model: AWRDACPI BIOS: Phoenix - AwardBIOS v6.00PG Processor: AMD Sempron(tm) Processor 2800+, ~1.6GHz Memory: 2048MB RAM Available OS Memory: 2046MB RAM DirectX Version: DirectX 11 DX Setup Parameters: Not found User DPI Setting: Using System DPI System DPI Setting: 96 DPI (100 percent) DWM DPI Scaling: Disabled ------------ DxDiag Notes ------------ Sound Tab 1: No sound card was found. If one is expected, you should install a sound driver provided by the hardware manufacturer. Input Tab: No problems found. -------------------- DirectX Debug Levels -------------------- Direct3D: 0/4 (retail) DirectDraw: 0/4 (retail) DirectInput: 0/5 (retail) DirectMusic: 0/5 (retail) DirectPlay: 0/9 (retail) DirectSound: 0/5 (retail) DirectShow: 0/6 (retail) ------------- Sound Devices ------------- Description: Default Sound Playback: No Default Voice Playback: No Hardware ID: Manufacturer ID: Product ID: Type: Driver Name: Driver Version: Driver Attributes: WHQL Logo'd: Date and Size: Other Files: Driver Provider: HW Accel Level: Emulation Only Cap Flags: 0x0 Min/Max Sample Rate: 0, 0 Static/Strm HW Mix Bufs: 0, 0 Static/Strm HW 3D Bufs: 0, 0 HW Memory: 0 Voice Management: No EAX(tm) 2.0 Listen/Src: No, No I3DL2(tm) Listen/Src: No, No Sensaura(tm) ZoomFX(tm): No --------------------- Sound Capture Devices --------------------- ------------------------ Disk & DVD/CD-ROM Drives ------------------------ Drive: C: Free Space: 25.9 GB Total Space: 40.0 GB File System: NTFS Model: Maxtor 6Y080L0 ATA Device Drive: D: Free Space: 33.1 GB Total Space: 38.2 GB File System: NTFS Model: Maxtor 6Y080L0 ATA Device -------------- System Devices -------------- Name: SiS 900-Based PCI Fast Ethernet Adapter Device ID: PCI\VEN_1039&DEV_0900&SUBSYS_0C92105B&REV_91\3&2B8E0B4B&0&20 Driver: C:\Windows\system32\DRIVERS\sisnic.sys, 2.00.1039.1210 (English), 7/13/2006 18:32:54, 40840 bytes Name: ATI Radeon 9600 / X1050 Series Secondary Device ID: PCI\VEN_1002&DEV_4172&SUBSYS_169118BC&REV_00\4&330C319E&0&0108 Driver: C:\Windows\system32\DRIVERS\atikmdag.sys, 8.01.0001.0882 (English), 2/11/2010 15:42:22, 4450816 bytes Driver: C:\Windows\system32\DRIVERS\ati2erec.dll, 1.00.0000.0018 (English), 2/11/2010 12:34:44, 53248 bytes Driver: C:\Windows\system32\atiumdag.dll, 8.14.0010.0647 (English), 2/11/2010 13:17:14, 3839488 bytes Driver: C:\Windows\system32\atiumdva.dll, 7.14.0010.0218 (English), 2/11/2010 13:00:38, 4946432 bytes Driver: C:\Windows\system32\atitmmxx.dll, 6.14.0011.0021 (English), 2/11/2010 13:30:38, 159744 bytes Driver: C:\Windows\system32\atiicdxx.dat, 4/24/2009 06:29:16, 189051 bytes Driver: C:\Windows\system32\amdpcom32.dll, 7.14.0010.0023 (English), 2/11/2010 12:49:00, 51712 bytes Driver: C:\Windows\system32\atiadlxx.dll, 6.14.0010.1032 (English), 2/11/2010 12:48:28, 135168 bytes Driver: C:\Windows\system32\atiumdva.cap, 2/11/2010 13:00:10, 152496 bytes Driver: C:\Windows\system32\atimuixx.dll, 6.14.0010.1001 (English), 2/11/2010 13:29:58, 12288 bytes Driver: C:\Windows\system32\Ati2evxx.exe, 6.14.0010.4222 (English), 2/11/2010 13:28:32, 733184 bytes Driver: C:\Windows\system32\Ati2evxx.dll, 6.14.0010.4178 (English), 2/11/2010 13:29:38, 278528 bytes Driver: C:\Windows\system32\atipdlxx.dll, 6.14.0010.2550 (English), 2/11/2010 13:30:20, 348160 bytes Driver: C:\Windows\system32\Oemdspif.dll, 6.15.0006.0004 (English), 2/11/2010 13:30:06, 274432 bytes Driver: C:\Windows\system32\ati2edxx.dll, 6.14.0010.2514 (English), 2/11/2010 13:29:50, 43520 bytes Driver: C:\Windows\system32\ATIDEMGX.dll, 2.00.3694.0978 (English), 2/11/2010 13:32:36, 442368 bytes Driver: C:\Windows\system32\atioglxx.dll, 6.14.0010.8545 (English), 2/11/2010 12:58:04, 11513856 bytes Driver: C:\Windows\system32\aticaldd.dll, 6.14.0010.0227 (English), 2/11/2010 12:42:40, 3235840 bytes Driver: C:\Windows\system32\aticalrt.dll, 6.14.0010.0227 (English), 2/11/2010 12:43:56, 53248 bytes Driver: C:\Windows\system32\aticalcl.dll, 6.14.0010.0227 (English), 2/11/2010 12:43:44, 53248 bytes Driver: C:\Windows\system32\atibrtmon.exe, 2.00.0000.0000 (English), 10/22/2008 01:51:42, 118784 bytes Driver: C:\Windows\atiogl.xml, 4/17/2009 00:19:48, 15577 bytes Name: SiS760 Host CPU Bridge Device ID: PCI\VEN_1039&DEV_0760&SUBSYS_0C92105B&REV_03\3&2B8E0B4B&0&00 Driver: n/a Name: ATI Radeon 9600 / X1050 Series Device ID: PCI\VEN_1002&DEV_4152&SUBSYS_169018BC&REV_00\4&330C319E&0&0008 Driver: C:\Windows\system32\DRIVERS\atikmdag.sys, 8.01.0001.0882 (English), 2/11/2010 15:42:22, 4450816 bytes Driver: C:\Windows\system32\DRIVERS\ati2erec.dll, 1.00.0000.0018 (English), 2/11/2010 12:34:44, 53248 bytes Driver: C:\Windows\system32\atiumdag.dll, 8.14.0010.0647 (English), 2/11/2010 13:17:14, 3839488 bytes Driver: C:\Windows\system32\atiumdva.dll, 7.14.0010.0218 (English), 2/11/2010 13:00:38, 4946432 bytes Driver: C:\Windows\system32\atitmmxx.dll, 6.14.0011.0021 (English), 2/11/2010 13:30:38, 159744 bytes Driver: C:\Windows\system32\atiicdxx.dat, 4/24/2009 06:29:16, 189051 bytes Driver: C:\Windows\system32\amdpcom32.dll, 7.14.0010.0023 (English), 2/11/2010 12:49:00, 51712 bytes Driver: C:\Windows\system32\atiadlxx.dll, 6.14.0010.1032 (English), 2/11/2010 12:48:28, 135168 bytes Driver: C:\Windows\system32\atiumdva.cap, 2/11/2010 13:00:10, 152496 bytes Driver: C:\Windows\system32\atimuixx.dll, 6.14.0010.1001 (English), 2/11/2010 13:29:58, 12288 bytes Driver: C:\Windows\system32\Ati2evxx.exe, 6.14.0010.4222 (English), 2/11/2010 13:28:32, 733184 bytes Driver: C:\Windows\system32\Ati2evxx.dll, 6.14.0010.4178 (English), 2/11/2010 13:29:38, 278528 bytes Driver: C:\Windows\system32\atipdlxx.dll, 6.14.0010.2550 (English), 2/11/2010 13:30:20, 348160 bytes Driver: C:\Windows\system32\Oemdspif.dll, 6.15.0006.0004 (English), 2/11/2010 13:30:06, 274432 bytes Driver: C:\Windows\system32\ati2edxx.dll, 6.14.0010.2514 (English), 2/11/2010 13:29:50, 43520 bytes Driver: C:\Windows\system32\ATIDEMGX.dll, 2.00.3694.0978 (English), 2/11/2010 13:32:36, 442368 bytes Driver: C:\Windows\system32\atioglxx.dll, 6.14.0010.8545 (English), 2/11/2010 12:58:04, 11513856 bytes Driver: C:\Windows\system32\aticaldd.dll, 6.14.0010.0227 (English), 2/11/2010 12:42:40, 3235840 bytes Driver: C:\Windows\system32\aticalrt.dll, 6.14.0010.0227 (English), 2/11/2010 12:43:56, 53248 bytes Driver: C:\Windows\system32\aticalcl.dll, 6.14.0010.0227 (English), 2/11/2010 12:43:44, 53248 bytes Driver: C:\Windows\system32\atibrtmon.exe, 2.00.0000.0000 (English), 10/22/2008 01:51:42, 118784 bytes Driver: C:\Windows\atiogl.xml, 4/17/2009 00:19:48, 15577 bytes Name: SiS 180 RAID Controller Device ID: PCI\VEN_1039&DEV_0180&SUBSYS_0C92105B&REV_01\3&2B8E0B4B&0&28 Driver: C:\Windows\system32\DRIVERS\sisraid2.sys, 5.01.1039.2600 (English), 7/14/2009 09:19:04, 40016 bytes Name: SiS 7001 PCI to USB Open Host Controller Device ID: PCI\VEN_1039&DEV_7001&SUBSYS_0C92105B&REV_0F\3&2B8E0B4B&0&1A Driver: C:\Windows\system32\drivers\usbohci.sys, 6.01.7601.17586 (English), 3/25/2011 10:57:58, 20480 bytes Driver: C:\Windows\system32\drivers\usbport.sys, 6.01.7601.17586 (English), 3/25/2011 10:58:07, 284672 bytes Driver: C:\Windows\system32\drivers\usbhub.sys, 6.01.7601.17586 (English), 3/25/2011 10:58:37, 258560 bytes Name: SIS Processor to AGP Controller Device ID: PCI\VEN_1039&DEV_0002&SUBSYS_00000000&REV_00\3&2B8E0B4B&0&08 Driver: C:\Windows\system32\DRIVERS\GAGP30KX.SYS, 6.01.7600.16385 (English), 7/14/2009 09:20:28, 57936 bytes Name: SiS 7001 PCI to USB Open Host Controller Device ID: PCI\VEN_1039&DEV_7001&SUBSYS_0C92105B&REV_0F\3&2B8E0B4B&0&19 Driver: C:\Windows\system32\drivers\usbohci.sys, 6.01.7601.17586 (English), 3/25/2011 10:57:58, 20480 bytes Driver: C:\Windows\system32\drivers\usbport.sys, 6.01.7601.17586 (English), 3/25/2011 10:58:07, 284672 bytes Driver: C:\Windows\system32\drivers\usbhub.sys, 6.01.7601.17586 (English), 3/25/2011 10:58:37, 258560 bytes Name: AMD Miscellaneous Configuration Device ID: PCI\VEN_1022&DEV_1103&SUBSYS_00000000&REV_00\3&2B8E0B4B&0&C3 Driver: n/a Name: SiS 7001 PCI to USB Open Host Controller Device ID: PCI\VEN_1039&DEV_7001&SUBSYS_0C92105B&REV_0F\3&2B8E0B4B&0&18 Driver: C:\Windows\system32\drivers\usbohci.sys, 6.01.7601.17586 (English), 3/25/2011 10:57:58, 20480 bytes Driver: C:\Windows\system32\drivers\usbport.sys, 6.01.7601.17586 (English), 3/25/2011 10:58:07, 284672 bytes Driver: C:\Windows\system32\drivers\usbhub.sys, 6.01.7601.17586 (English), 3/25/2011 10:58:37, 258560 bytes Name: AMD DRAM and HyperTransport(tm) Trace Mode Configuration Device ID: PCI\VEN_1022&DEV_1102&SUBSYS_00000000&REV_00\3&2B8E0B4B&0&C2 Driver: n/a Name: SiS PCI IDE Controller Device ID: PCI\VEN_1039&DEV_5513&SUBSYS_0C92105B&REV_01\3&2B8E0B4B&0&15 Driver: C:\Windows\system32\DRIVERS\pciide.sys, 6.01.7600.16385 (English), 7/14/2009 09:20:45, 12368 bytes Driver: C:\Windows\system32\DRIVERS\pciidex.sys, 6.01.7600.16385 (English), 7/14/2009 09:19:03, 42560 bytes Driver: C:\Windows\system32\DRIVERS\atapi.sys, 6.01.7600.16385 (English), 7/14/2009 09:26:15, 21584 bytes Driver: C:\Windows\system32\DRIVERS\ataport.sys, 6.01.7601.17514 (English), 11/21/2010 05:29:03, 132992 bytes Name: AMD Address Map Configuration Device ID: PCI\VEN_1022&DEV_1101&SUBSYS_00000000&REV_00\3&2B8E0B4B&0&C1 Driver: n/a Name: SiS964 PCI to LPC Bridge Device ID: PCI\VEN_1039&DEV_0964&SUBSYS_00000000&REV_36\3&2B8E0B4B&0&10 Driver: C:\Windows\system32\DRIVERS\msisadrv.sys, 6.01.7600.16385 (English), 7/14/2009 09:20:43, 13888 bytes Name: AMD HyperTransport(tm) Configuration Device ID: PCI\VEN_1022&DEV_1100&SUBSYS_00000000&REV_00\3&2B8E0B4B&0&C0 Driver: n/a ------------------ DirectShow Filters ------------------ DirectShow Filters: WMAudio Decoder DMO,0x00800800,1,1,WMADMOD.DLL,6.01.7601.17514 WMAPro over S/PDIF DMO,0x00600800,1,1,WMADMOD.DLL,6.01.7601.17514 WMSpeech Decoder DMO,0x00600800,1,1,WMSPDMOD.DLL,6.01.7601.17514 MP3 Decoder DMO,0x00600800,1,1,mp3dmod.dll,6.01.7600.16385 Mpeg4s Decoder DMO,0x00800001,1,1,mp4sdecd.dll,6.01.7600.16385 WMV Screen decoder DMO,0x00600800,1,1,wmvsdecd.dll,6.01.7601.17514 WMVideo Decoder DMO,0x00800001,1,1,wmvdecod.dll,6.01.7601.17514 Mpeg43 Decoder DMO,0x00800001,1,1,mp43decd.dll,6.01.7600.16385 Mpeg4 Decoder DMO,0x00800001,1,1,mpg4decd.dll,6.01.7600.16385 ATI Ticker,0x00200000,0,1,Ticker.ax, DV Muxer,0x00400000,0,0,qdv.dll,6.06.7601.17514 Color Space Converter,0x00400001,1,1,quartz.dll,6.06.7601.17713 WM ASF Reader,0x00400000,0,0,qasf.dll,12.00.7601.17514 Screen Capture filter,0x00200000,0,1,wmpsrcwp.dll,12.00.7601.17514 AVI Splitter,0x00600000,1,1,quartz.dll,6.06.7601.17713 VGA 16 Color Ditherer,0x00400000,1,1,quartz.dll,6.06.7601.17713 SBE2MediaTypeProfile,0x00200000,0,0,sbe.dll,6.06.7601.17528 Microsoft DTV-DVD Video Decoder,0x005fffff,2,4,msmpeg2vdec.dll,12.00.9200.16426 AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,6.06.7601.17528 StreamBufferSink,0x00200000,0,0,sbe.dll,6.06.7601.17528 Microsoft TV Captions Decoder,0x00200001,1,0,MSTVCapn.dll,6.01.7601.17715 MJPEG Decompressor,0x00600000,1,1,quartz.dll,6.06.7601.17713 CBVA DMO wrapper filter,0x00200000,1,1,cbva.dll,6.01.7601.17514 MPEG-I Stream Splitter,0x00600000,1,2,quartz.dll,6.06.7601.17713 SAMI (CC) Parser,0x00400000,1,1,quartz.dll,6.06.7601.17713 VBI Codec,0x00600000,1,4,VBICodec.ax,6.06.7601.17514 MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,6.06.7601.17528 Closed Captions Analysis Filter,0x00200000,2,5,cca.dll,6.06.7601.17514 SBE2FileScan,0x00200000,0,0,sbe.dll,6.06.7601.17528 Microsoft MPEG-2 Video Encoder,0x00200000,1,1,msmpeg2enc.dll,6.01.7601.17514 Internal Script Command Renderer,0x00800001,1,0,quartz.dll,6.06.7601.17713 MPEG Audio Decoder,0x03680001,1,1,quartz.dll,6.06.7601.17713 MMACE ProcAmp,0x00200000,0,2,MMACEFilters.dll, DV Splitter,0x00600000,1,2,qdv.dll,6.06.7601.17514 Video Mixing Renderer 9,0x00200000,1,0,quartz.dll,6.06.7601.17713 Microsoft MPEG-2 Encoder,0x00200000,2,1,msmpeg2enc.dll,6.01.7601.17514 Xvid MPEG-4 Video Decoder,0x00800002,1,1,xvid.ax, ACM Wrapper,0x00600000,1,1,quartz.dll,6.06.7601.17713 Video Renderer,0x00800001,1,0,quartz.dll,6.06.7601.17713 MPEG-2 Video Stream Analyzer,0x00200000,0,0,sbe.dll,6.06.7601.17528 Line 21 Decoder,0x00600000,1,1,qdvd.dll,6.06.7601.17713 Video Port Manager,0x00600000,2,1,quartz.dll,6.06.7601.17713 Video Renderer,0x00400000,1,0,quartz.dll,6.06.7601.17713 VPS Decoder,0x00200000,0,0,WSTPager.ax,6.06.7601.17514 WM ASF Writer,0x00400000,0,0,qasf.dll,12.00.7601.17514 VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,6.01.7601.17514 MMACE SoftEmu,0x00200000,0,2,MMACEFilters.dll, File writer,0x00200000,1,0,qcap.dll,6.06.7601.17514 iTV Data Sink,0x00600000,1,0,itvdata.dll,6.06.7601.17514 iTV Data Capture filter,0x00600000,1,1,itvdata.dll,6.06.7601.17514 DVD Navigator,0x00200000,0,3,qdvd.dll,6.06.7601.17713 MMACE DeInterlace,0x00200000,0,2,MMACEFilters.dll, Microsoft TV Subtitles Decoder,0x00200001,1,0,MSTVCapn.dll,6.01.7601.17715 Overlay Mixer2,0x00200000,1,1,qdvd.dll,6.06.7601.17713 AVI Draw,0x00600064,9,1,quartz.dll,6.06.7601.17713 RDP DShow Redirection Filter,0xffffffff,1,0,DShowRdpFilter.dll, Microsoft MPEG-2 Audio Encoder,0x00200000,1,1,msmpeg2enc.dll,6.01.7601.17514 WST Pager,0x00200000,1,1,WSTPager.ax,6.06.7601.17514 MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,6.06.7601.17528 DV Video Decoder,0x00800000,1,1,qdv.dll,6.06.7601.17514 SampleGrabber,0x00200000,1,1,qedit.dll,6.06.7601.17514 Null Renderer,0x00200000,1,0,qedit.dll,6.06.7601.17514 MPEG-2 Sections and Tables,0x005fffff,1,0,Mpeg2Data.ax,6.06.7601.17514 Microsoft AC3 Encoder,0x00200000,1,1,msac3enc.dll,6.01.7601.17514 StreamBufferSource,0x00200000,0,0,sbe.dll,6.06.7601.17528 Smart Tee,0x00200000,1,2,qcap.dll,6.06.7601.17514 Overlay Mixer,0x00200000,0,0,qdvd.dll,6.06.7601.17713 AVI Decompressor,0x00600000,1,1,quartz.dll,6.06.7601.17713 NetBridge,0x00200000,2,0,netbridge.dll,6.01.7601.17514 AVI/WAV File Source,0x00400000,0,2,quartz.dll,6.06.7601.17713 Wave Parser,0x00400000,1,1,quartz.dll,6.06.7601.17713 MIDI Parser,0x00400000,1,1,quartz.dll,6.06.7601.17713 Multi-file Parser,0x00400000,1,1,quartz.dll,6.06.7601.17713 File stream renderer,0x00400000,1,1,quartz.dll,6.06.7601.17713 Microsoft DTV-DVD Audio Decoder,0x005fffff,1,1,msmpeg2adec.dll,6.01.7140.0000 StreamBufferSink2,0x00200000,0,0,sbe.dll,6.06.7601.17528 AVI Mux,0x00200000,1,0,qcap.dll,6.06.7601.17514 Line 21 Decoder 2,0x00600002,1,1,quartz.dll,6.06.7601.17713 File Source (Async.),0x00400000,0,1,quartz.dll,6.06.7601.17713 File Source (URL),0x00400000,0,1,quartz.dll,6.06.7601.17713 Media Center Extender Encryption Filter,0x00200000,2,2,Mcx2Filter.dll,6.01.7601.17514 AudioRecorder WAV Dest,0x00200000,0,0,WavDest.dll, AudioRecorder Wave Form,0x00200000,0,0,WavDest.dll, SoundRecorder Null Renderer,0x00200000,0,0,WavDest.dll, Infinite Pin Tee Filter,0x00200000,1,1,qcap.dll,6.06.7601.17514 Enhanced Video Renderer,0x00200000,1,0,evr.dll,6.01.7601.17514 BDA MPEG2 Transport Information Filter,0x00200000,2,0,psisrndr.ax,6.06.7601.17669 MPEG Video Decoder,0x40000001,1,1,quartz.dll,6.06.7601.17713 Video Compressors: WMVideo8 Encoder DMO,0x00600800,1,1,wmvxencd.dll,6.01.7600.16385 WMVideo9 Encoder DMO,0x00600800,1,1,wmvencod.dll,6.01.7600.16385 MSScreen 9 encoder DMO,0x00600800,1,1,wmvsencd.dll,6.01.7600.16385 DV Video Encoder,0x00200000,0,0,qdv.dll,6.06.7601.17514 MJPEG Compressor,0x00200000,0,0,quartz.dll,6.06.7601.17713 Cinepak Codec by Radius,0x00200000,1,1,qcap.dll,6.06.7601.17514 Fraps Video Decompressor,0x00200000,1,1,qcap.dll,6.06.7601.17514 Intel IYUV codec,0x00200000,1,1,qcap.dll,6.06.7601.17514 Intel IYUV codec,0x00200000,1,1,qcap.dll,6.06.7601.17514 Microsoft RLE,0x00200000,1,1,qcap.dll,6.06.7601.17514 Microsoft Video 1,0x00200000,1,1,qcap.dll,6.06.7601.17514 Xvid MPEG-4 Codec,0x00200000,1,1,qcap.dll,6.06.7601.17514 Audio Compressors: WM Speech Encoder DMO,0x00600800,1,1,WMSPDMOE.DLL,6.01.7600.16385 WMAudio Encoder DMO,0x00600800,1,1,WMADMOE.DLL,6.01.7600.16385 IMA ADPCM,0x00200000,1,1,quartz.dll,6.06.7601.17713 PCM,0x00200000,1,1,quartz.dll,6.06.7601.17713 Microsoft ADPCM,0x00200000,1,1,quartz.dll,6.06.7601.17713 GSM 6.10,0x00200000,1,1,quartz.dll,6.06.7601.17713 CCITT A-Law,0x00200000,1,1,quartz.dll,6.06.7601.17713 CCITT u-Law,0x00200000,1,1,quartz.dll,6.06.7601.17713 MPEG Layer-3,0x00200000,1,1,quartz.dll,6.06.7601.17713 PBDA CP Filters: PBDA DTFilter,0x00600000,1,1,CPFilters.dll,6.06.7601.17528 PBDA ETFilter,0x00200000,0,0,CPFilters.dll,6.06.7601.17528 PBDA PTFilter,0x00200000,0,0,CPFilters.dll,6.06.7601.17528 Midi Renderers: Default MidiOut Device,0x00800000,1,0,quartz.dll,6.06.7601.17713 BDA Network Providers: Microsoft ATSC Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7601.17514 Microsoft DVBC Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7601.17514 Microsoft DVBS Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7601.17514 Microsoft DVBT Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7601.17514 Microsoft Network Provider,0x00200000,0,1,MSNP.ax,6.06.7601.17514 Multi-Instance Capable VBI Codecs: VBI Codec,0x00600000,1,4,VBICodec.ax,6.06.7601.17514 BDA Transport Information Renderers: BDA MPEG2 Transport Information Filter,0x00600000,2,0,psisrndr.ax,6.06.7601.17669 MPEG-2 Sections and Tables,0x00600000,1,0,Mpeg2Data.ax,6.06.7601.17514 BDA CP/CA Filters: Decrypt/Tag,0x00600000,1,1,EncDec.dll,6.06.7601.17708 Encrypt/Tag,0x00200000,0,0,EncDec.dll,6.06.7601.17708 PTFilter,0x00200000,0,0,EncDec.dll,6.06.7601.17708 XDS Codec,0x00200000,0,0,EncDec.dll,6.06.7601.17708 Audio Renderers: Default DirectSound Device,0x00800000,1,0,quartz.dll,6.06.7601.17713 Default WaveOut Device,0x00200000,1,0,quartz.dll,6.06.7601.17713
In my previous OS, I was using SoundMax Audio.
I hope you could provide me exact solutions for this.
Thank you in advance <3
