Solved No Audio Output Device Installed/No sound card found
Hones Tea
5:27 PM
Hello all,
I hope you could help me with my problem.
Recently, I got problem with my PC, just all of a sudden, it stopped booting and later on the HDD got wiped and I have no saved data. So I reinstalled using USB, before I was running Windows XP, but I prefer to install Windows 7. The thing is, I don't have sound anymore.
Here's everything you need, this is my DxDiag.txt file
System Information
Operating System: Windows 7 Professional 32-bit (6.1, Build 7601) Service Pack 1 (7601.win7sp1_gdr.130318-1533)
Language: English (Regional Setting: English)
System Manufacturer: AWARD_
System Model: AWRDACPI
BIOS: Phoenix - AwardBIOS v6.00PG
Processor: AMD Sempron(tm) Processor 2800+, ~1.6GHz
Memory: 2048MB RAM
Available OS Memory: 2046MB RAM
DirectX Version: DirectX 11
DX Setup Parameters: Not found
User DPI Setting: Using System DPI
 System DPI Setting: 96 DPI (100 percent)
    DWM DPI Scaling: Disabled
DxDiag Notes
Sound Tab 1: No sound card was found.  If one is expected, you should install a sound driver provided by the hardware manufacturer.
Input Tab: No problems found.
DirectX Debug Levels
Direct3D:    0/4 (retail)
DirectDraw:  0/4 (retail)
DirectInput: 0/5 (retail)
DirectMusic: 0/5 (retail)
DirectPlay:  0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow:  0/6 (retail)
Sound Devices
            Description:
 Default Sound Playback: No
 Default Voice Playback: No
            Hardware ID:
        Manufacturer ID:
             Product ID:
                   Type:
            Driver Name:
         Driver Version:
      Driver Attributes:
            WHQL Logo'd:
          Date and Size:
            Other Files:
        Driver Provider:
         HW Accel Level: Emulation Only
              Cap Flags: 0x0
    Min/Max Sample Rate: 0, 0
Static/Strm HW Mix Bufs: 0, 0
 Static/Strm HW 3D Bufs: 0, 0
              HW Memory: 0
       Voice Management: No
 EAX(tm) 2.0 Listen/Src: No, No
   I3DL2(tm) Listen/Src: No, No
Sensaura(tm) ZoomFX(tm): No
Sound Capture Devices
Disk & DVD/CD-ROM Drives
      Drive: C:
 Free Space: 25.9 GB
Total Space: 40.0 GB
File System: NTFS
      Model: Maxtor 6Y080L0 ATA Device
      Drive: D:
 Free Space: 33.1 GB
Total Space: 38.2 GB
File System: NTFS
System Devices
     Name: SiS 900-Based PCI Fast Ethernet Adapter
Device ID: PCI\VEN_1039&DEV_0900&SUBSYS_0C92105B&REV_91\3&2B8E0B4B&0&20
   Driver: C:\Windows\system32\DRIVERS\sisnic.sys, 2.00.1039.1210 (English), 7/13/2006 18:32:54, 40840 bytes
     Name: ATI Radeon 9600 / X1050 Series Secondary
Device ID: PCI\VEN_1002&DEV_4172&SUBSYS_169118BC&REV_00\4&330C319E&0&0108
   Driver: C:\Windows\system32\DRIVERS\atikmdag.sys, 8.01.0001.0882 (English), 2/11/2010 15:42:22, 4450816 bytes
   Driver: C:\Windows\system32\DRIVERS\ati2erec.dll, 1.00.0000.0018 (English), 2/11/2010 12:34:44, 53248 bytes
   Driver: C:\Windows\system32\atiumdag.dll, 8.14.0010.0647 (English), 2/11/2010 13:17:14, 3839488 bytes
   Driver: C:\Windows\system32\atiumdva.dll, 7.14.0010.0218 (English), 2/11/2010 13:00:38, 4946432 bytes
   Driver: C:\Windows\system32\atitmmxx.dll, 6.14.0011.0021 (English), 2/11/2010 13:30:38, 159744 bytes
   Driver: C:\Windows\system32\atiicdxx.dat, 4/24/2009 06:29:16, 189051 bytes
   Driver: C:\Windows\system32\amdpcom32.dll, 7.14.0010.0023 (English), 2/11/2010 12:49:00, 51712 bytes
   Driver: C:\Windows\system32\atiadlxx.dll, 6.14.0010.1032 (English), 2/11/2010 12:48:28, 135168 bytes
   Driver: C:\Windows\system32\atiumdva.cap, 2/11/2010 13:00:10, 152496 bytes
   Driver: C:\Windows\system32\atimuixx.dll, 6.14.0010.1001 (English), 2/11/2010 13:29:58, 12288 bytes
   Driver: C:\Windows\system32\Ati2evxx.exe, 6.14.0010.4222 (English), 2/11/2010 13:28:32, 733184 bytes
   Driver: C:\Windows\system32\Ati2evxx.dll, 6.14.0010.4178 (English), 2/11/2010 13:29:38, 278528 bytes
   Driver: C:\Windows\system32\atipdlxx.dll, 6.14.0010.2550 (English), 2/11/2010 13:30:20, 348160 bytes
   Driver: C:\Windows\system32\Oemdspif.dll, 6.15.0006.0004 (English), 2/11/2010 13:30:06, 274432 bytes
   Driver: C:\Windows\system32\ati2edxx.dll, 6.14.0010.2514 (English), 2/11/2010 13:29:50, 43520 bytes
   Driver: C:\Windows\system32\ATIDEMGX.dll, 2.00.3694.0978 (English), 2/11/2010 13:32:36, 442368 bytes
   Driver: C:\Windows\system32\atioglxx.dll, 6.14.0010.8545 (English), 2/11/2010 12:58:04, 11513856 bytes
   Driver: C:\Windows\system32\aticaldd.dll, 6.14.0010.0227 (English), 2/11/2010 12:42:40, 3235840 bytes
   Driver: C:\Windows\system32\aticalrt.dll, 6.14.0010.0227 (English), 2/11/2010 12:43:56, 53248 bytes
   Driver: C:\Windows\system32\aticalcl.dll, 6.14.0010.0227 (English), 2/11/2010 12:43:44, 53248 bytes
   Driver: C:\Windows\system32\atibrtmon.exe, 2.00.0000.0000 (English), 10/22/2008 01:51:42, 118784 bytes
   Driver: C:\Windows\atiogl.xml, 4/17/2009 00:19:48, 15577 bytes
     Name: SiS760  Host CPU Bridge
Device ID: PCI\VEN_1039&DEV_0760&SUBSYS_0C92105B&REV_03\3&2B8E0B4B&0&00
   Driver: n/a
Device ID: PCI\VEN_1002&DEV_4152&SUBSYS_169018BC&REV_00\4&330C319E&0&0008
     Name: SiS 180 RAID Controller
Device ID: PCI\VEN_1039&DEV_0180&SUBSYS_0C92105B&REV_01\3&2B8E0B4B&0&28
   Driver: C:\Windows\system32\DRIVERS\sisraid2.sys, 5.01.1039.2600 (English), 7/14/2009 09:19:04, 40016 bytes
     Name: SiS 7001 PCI to USB Open Host Controller
Device ID: PCI\VEN_1039&DEV_7001&SUBSYS_0C92105B&REV_0F\3&2B8E0B4B&0&1A
   Driver: C:\Windows\system32\drivers\usbohci.sys, 6.01.7601.17586 (English), 3/25/2011 10:57:58, 20480 bytes
   Driver: C:\Windows\system32\drivers\usbport.sys, 6.01.7601.17586 (English), 3/25/2011 10:58:07, 284672 bytes
   Driver: C:\Windows\system32\drivers\usbhub.sys, 6.01.7601.17586 (English), 3/25/2011 10:58:37, 258560 bytes
     Name: SIS Processor to AGP Controller
Device ID: PCI\VEN_1039&DEV_0002&SUBSYS_00000000&REV_00\3&2B8E0B4B&0&08
   Driver: C:\Windows\system32\DRIVERS\GAGP30KX.SYS, 6.01.7600.16385 (English), 7/14/2009 09:20:28, 57936 bytes
Device ID: PCI\VEN_1039&DEV_7001&SUBSYS_0C92105B&REV_0F\3&2B8E0B4B&0&19
     Name: AMD Miscellaneous Configuration
Device ID: PCI\VEN_1022&DEV_1103&SUBSYS_00000000&REV_00\3&2B8E0B4B&0&C3
   Driver: n/a
Device ID: PCI\VEN_1039&DEV_7001&SUBSYS_0C92105B&REV_0F\3&2B8E0B4B&0&18
     Name: AMD DRAM and HyperTransport(tm) Trace Mode Configuration
Device ID: PCI\VEN_1022&DEV_1102&SUBSYS_00000000&REV_00\3&2B8E0B4B&0&C2
   Driver: n/a
     Name: SiS PCI IDE Controller
Device ID: PCI\VEN_1039&DEV_5513&SUBSYS_0C92105B&REV_01\3&2B8E0B4B&0&15
   Driver: C:\Windows\system32\DRIVERS\pciide.sys, 6.01.7600.16385 (English), 7/14/2009 09:20:45, 12368 bytes
   Driver: C:\Windows\system32\DRIVERS\pciidex.sys, 6.01.7600.16385 (English), 7/14/2009 09:19:03, 42560 bytes
   Driver: C:\Windows\system32\DRIVERS\atapi.sys, 6.01.7600.16385 (English), 7/14/2009 09:26:15, 21584 bytes
   Driver: C:\Windows\system32\DRIVERS\ataport.sys, 6.01.7601.17514 (English), 11/21/2010 05:29:03, 132992 bytes
     Name: AMD Address Map Configuration
Device ID: PCI\VEN_1022&DEV_1101&SUBSYS_00000000&REV_00\3&2B8E0B4B&0&C1
   Driver: n/a
     Name: SiS964  PCI to LPC Bridge
Device ID: PCI\VEN_1039&DEV_0964&SUBSYS_00000000&REV_36\3&2B8E0B4B&0&10
   Driver: C:\Windows\system32\DRIVERS\msisadrv.sys, 6.01.7600.16385 (English), 7/14/2009 09:20:43, 13888 bytes
     Name: AMD HyperTransport(tm) Configuration
Device ID: PCI\VEN_1022&DEV_1100&SUBSYS_00000000&REV_00\3&2B8E0B4B&0&C0
   Driver: n/a
DirectShow Filters
DirectShow Filters:
WMAudio Decoder DMO,0x00800800,1,1,WMADMOD.DLL,6.01.7601.17514
WMAPro over S/PDIF DMO,0x00600800,1,1,WMADMOD.DLL,6.01.7601.17514
WMSpeech Decoder DMO,0x00600800,1,1,WMSPDMOD.DLL,6.01.7601.17514
MP3 Decoder DMO,0x00600800,1,1,mp3dmod.dll,6.01.7600.16385
Mpeg4s Decoder DMO,0x00800001,1,1,mp4sdecd.dll,6.01.7600.16385
WMV Screen decoder DMO,0x00600800,1,1,wmvsdecd.dll,6.01.7601.17514
WMVideo Decoder DMO,0x00800001,1,1,wmvdecod.dll,6.01.7601.17514
Mpeg43 Decoder DMO,0x00800001,1,1,mp43decd.dll,6.01.7600.16385
Mpeg4 Decoder DMO,0x00800001,1,1,mpg4decd.dll,6.01.7600.16385
ATI Ticker,0x00200000,0,1,Ticker.ax,
DV Muxer,0x00400000,0,0,qdv.dll,6.06.7601.17514
Color Space Converter,0x00400001,1,1,quartz.dll,6.06.7601.17713
WM ASF Reader,0x00400000,0,0,qasf.dll,12.00.7601.17514
Screen Capture filter,0x00200000,0,1,wmpsrcwp.dll,12.00.7601.17514
AVI Splitter,0x00600000,1,1,quartz.dll,6.06.7601.17713
VGA 16 Color Ditherer,0x00400000,1,1,quartz.dll,6.06.7601.17713
SBE2MediaTypeProfile,0x00200000,0,0,sbe.dll,6.06.7601.17528
Microsoft DTV-DVD Video Decoder,0x005fffff,2,4,msmpeg2vdec.dll,12.00.9200.16426
AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,6.06.7601.17528
StreamBufferSink,0x00200000,0,0,sbe.dll,6.06.7601.17528
Microsoft TV Captions Decoder,0x00200001,1,0,MSTVCapn.dll,6.01.7601.17715
MJPEG Decompressor,0x00600000,1,1,quartz.dll,6.06.7601.17713
CBVA DMO wrapper filter,0x00200000,1,1,cbva.dll,6.01.7601.17514
MPEG-I Stream Splitter,0x00600000,1,2,quartz.dll,6.06.7601.17713
SAMI (CC) Parser,0x00400000,1,1,quartz.dll,6.06.7601.17713
VBI Codec,0x00600000,1,4,VBICodec.ax,6.06.7601.17514
MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,6.06.7601.17528
Closed Captions Analysis Filter,0x00200000,2,5,cca.dll,6.06.7601.17514
SBE2FileScan,0x00200000,0,0,sbe.dll,6.06.7601.17528
Microsoft MPEG-2 Video Encoder,0x00200000,1,1,msmpeg2enc.dll,6.01.7601.17514
Internal Script Command Renderer,0x00800001,1,0,quartz.dll,6.06.7601.17713
MPEG Audio Decoder,0x03680001,1,1,quartz.dll,6.06.7601.17713
MMACE ProcAmp,0x00200000,0,2,MMACEFilters.dll,
DV Splitter,0x00600000,1,2,qdv.dll,6.06.7601.17514
Video Mixing Renderer 9,0x00200000,1,0,quartz.dll,6.06.7601.17713
Microsoft MPEG-2 Encoder,0x00200000,2,1,msmpeg2enc.dll,6.01.7601.17514
Xvid MPEG-4 Video Decoder,0x00800002,1,1,xvid.ax,
ACM Wrapper,0x00600000,1,1,quartz.dll,6.06.7601.17713
Video Renderer,0x00800001,1,0,quartz.dll,6.06.7601.17713
MPEG-2 Video Stream Analyzer,0x00200000,0,0,sbe.dll,6.06.7601.17528
Line 21 Decoder,0x00600000,1,1,qdvd.dll,6.06.7601.17713
Video Port Manager,0x00600000,2,1,quartz.dll,6.06.7601.17713
Video Renderer,0x00400000,1,0,quartz.dll,6.06.7601.17713
VPS Decoder,0x00200000,0,0,WSTPager.ax,6.06.7601.17514
WM ASF Writer,0x00400000,0,0,qasf.dll,12.00.7601.17514
VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,6.01.7601.17514
MMACE SoftEmu,0x00200000,0,2,MMACEFilters.dll,
File writer,0x00200000,1,0,qcap.dll,6.06.7601.17514
iTV Data Sink,0x00600000,1,0,itvdata.dll,6.06.7601.17514
iTV Data Capture filter,0x00600000,1,1,itvdata.dll,6.06.7601.17514
DVD Navigator,0x00200000,0,3,qdvd.dll,6.06.7601.17713
MMACE DeInterlace,0x00200000,0,2,MMACEFilters.dll,
Microsoft TV Subtitles Decoder,0x00200001,1,0,MSTVCapn.dll,6.01.7601.17715
Overlay Mixer2,0x00200000,1,1,qdvd.dll,6.06.7601.17713
AVI Draw,0x00600064,9,1,quartz.dll,6.06.7601.17713
RDP DShow Redirection Filter,0xffffffff,1,0,DShowRdpFilter.dll,
Microsoft MPEG-2 Audio Encoder,0x00200000,1,1,msmpeg2enc.dll,6.01.7601.17514
WST Pager,0x00200000,1,1,WSTPager.ax,6.06.7601.17514
MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,6.06.7601.17528
DV Video Decoder,0x00800000,1,1,qdv.dll,6.06.7601.17514
SampleGrabber,0x00200000,1,1,qedit.dll,6.06.7601.17514
Null Renderer,0x00200000,1,0,qedit.dll,6.06.7601.17514
MPEG-2 Sections and Tables,0x005fffff,1,0,Mpeg2Data.ax,6.06.7601.17514
Microsoft AC3 Encoder,0x00200000,1,1,msac3enc.dll,6.01.7601.17514
StreamBufferSource,0x00200000,0,0,sbe.dll,6.06.7601.17528
Smart Tee,0x00200000,1,2,qcap.dll,6.06.7601.17514
Overlay Mixer,0x00200000,0,0,qdvd.dll,6.06.7601.17713
AVI Decompressor,0x00600000,1,1,quartz.dll,6.06.7601.17713
NetBridge,0x00200000,2,0,netbridge.dll,6.01.7601.17514
AVI/WAV File Source,0x00400000,0,2,quartz.dll,6.06.7601.17713
Wave Parser,0x00400000,1,1,quartz.dll,6.06.7601.17713
MIDI Parser,0x00400000,1,1,quartz.dll,6.06.7601.17713
Multi-file Parser,0x00400000,1,1,quartz.dll,6.06.7601.17713
File stream renderer,0x00400000,1,1,quartz.dll,6.06.7601.17713
Microsoft DTV-DVD Audio Decoder,0x005fffff,1,1,msmpeg2adec.dll,6.01.7140.0000
StreamBufferSink2,0x00200000,0,0,sbe.dll,6.06.7601.17528
AVI Mux,0x00200000,1,0,qcap.dll,6.06.7601.17514
Line 21 Decoder 2,0x00600002,1,1,quartz.dll,6.06.7601.17713
File Source (Async.),0x00400000,0,1,quartz.dll,6.06.7601.17713
File Source (URL),0x00400000,0,1,quartz.dll,6.06.7601.17713
Media Center Extender Encryption Filter,0x00200000,2,2,Mcx2Filter.dll,6.01.7601.17514
AudioRecorder WAV Dest,0x00200000,0,0,WavDest.dll,
AudioRecorder Wave Form,0x00200000,0,0,WavDest.dll,
SoundRecorder Null Renderer,0x00200000,0,0,WavDest.dll,
Infinite Pin Tee Filter,0x00200000,1,1,qcap.dll,6.06.7601.17514
Enhanced Video Renderer,0x00200000,1,0,evr.dll,6.01.7601.17514
BDA MPEG2 Transport Information Filter,0x00200000,2,0,psisrndr.ax,6.06.7601.17669
MPEG Video Decoder,0x40000001,1,1,quartz.dll,6.06.7601.17713
Video Compressors:
WMVideo8 Encoder DMO,0x00600800,1,1,wmvxencd.dll,6.01.7600.16385
WMVideo9 Encoder DMO,0x00600800,1,1,wmvencod.dll,6.01.7600.16385
MSScreen 9 encoder DMO,0x00600800,1,1,wmvsencd.dll,6.01.7600.16385
DV Video Encoder,0x00200000,0,0,qdv.dll,6.06.7601.17514
MJPEG Compressor,0x00200000,0,0,quartz.dll,6.06.7601.17713
Cinepak Codec by Radius,0x00200000,1,1,qcap.dll,6.06.7601.17514
Fraps Video Decompressor,0x00200000,1,1,qcap.dll,6.06.7601.17514
Intel IYUV codec,0x00200000,1,1,qcap.dll,6.06.7601.17514
Microsoft RLE,0x00200000,1,1,qcap.dll,6.06.7601.17514
Microsoft Video 1,0x00200000,1,1,qcap.dll,6.06.7601.17514
Xvid MPEG-4 Codec,0x00200000,1,1,qcap.dll,6.06.7601.17514
Audio Compressors:
WM Speech Encoder DMO,0x00600800,1,1,WMSPDMOE.DLL,6.01.7600.16385
WMAudio Encoder DMO,0x00600800,1,1,WMADMOE.DLL,6.01.7600.16385
IMA ADPCM,0x00200000,1,1,quartz.dll,6.06.7601.17713
Microsoft ADPCM,0x00200000,1,1,quartz.dll,6.06.7601.17713
GSM 6.10,0x00200000,1,1,quartz.dll,6.06.7601.17713
CCITT A-Law,0x00200000,1,1,quartz.dll,6.06.7601.17713
CCITT u-Law,0x00200000,1,1,quartz.dll,6.06.7601.17713
MPEG Layer-3,0x00200000,1,1,quartz.dll,6.06.7601.17713
PBDA CP Filters:
PBDA DTFilter,0x00600000,1,1,CPFilters.dll,6.06.7601.17528
PBDA ETFilter,0x00200000,0,0,CPFilters.dll,6.06.7601.17528
PBDA PTFilter,0x00200000,0,0,CPFilters.dll,6.06.7601.17528
Midi Renderers:
Default MidiOut Device,0x00800000,1,0,quartz.dll,6.06.7601.17713
BDA Network Providers:
Microsoft ATSC Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7601.17514
Microsoft DVBC Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7601.17514
Microsoft DVBS Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7601.17514
Microsoft DVBT Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7601.17514
Microsoft Network Provider,0x00200000,0,1,MSNP.ax,6.06.7601.17514
Multi-Instance Capable VBI Codecs:
BDA Transport Information Renderers:
BDA MPEG2 Transport Information Filter,0x00600000,2,0,psisrndr.ax,6.06.7601.17669
MPEG-2 Sections and Tables,0x00600000,1,0,Mpeg2Data.ax,6.06.7601.17514
BDA CP/CA Filters:
Decrypt/Tag,0x00600000,1,1,EncDec.dll,6.06.7601.17708
Encrypt/Tag,0x00200000,0,0,EncDec.dll,6.06.7601.17708
PTFilter,0x00200000,0,0,EncDec.dll,6.06.7601.17708
XDS Codec,0x00200000,0,0,EncDec.dll,6.06.7601.17708
Audio Renderers:
Default DirectSound Device,0x00800000,1,0,quartz.dll,6.06.7601.17713
Default WaveOut Device,0x00200000,1,0,quartz.dll,6.06.7601.17713
I don't have Sounds, Video and Game Controller tab in Device Manager.
In my previous OS, I was using SoundMax Audio.
I hope you could provide me exact solutions for this.
Thank you in advance <3
Microsoft Windows 7 Professional 32-bit 7601 ...AMD Sempron(tm) Processor 2800+2.00 GB(1) ATI Radeon 9600 / X1050 Series (2) ATI Ra...
AWARD_ , awardacpi
Microsoft Windows 7 Professional 32-bit 7601 Multiprocessor Free Service Pack 1
WinFast 760GXK8MC
2.00 GB
(1) ATI Radeon 9600 / X1050 Series (2) ATI Radeon 9600 / X
Maxtor 80gb
ESET NOD 32
Google chrome
Windows 7 ultimate x64
Nothing specific....what ever the clients provide for Repair
Hello centaur78,
Thank you for your response, here is the zipped file:
View attachment Hones Tea.zip
Moreover, I don't have CD Rom and I don't have CD or anything.
AWARD_ , awardacpi
WinFast 760GXK8MC
2.00 GB
Maxtor 80gb
ESET NOD 32
Google chrome
Done sir.
AWARD_ , awardacpi
WinFast 760GXK8MC
2.00 GB
Maxtor 80gb
ESET NOD 32
Google chrome
Hones
The first thing you need to know is that this motherboard is phased out by Foxconn... Its last BIOS/Driver updates where in 2007 !!
Having said that... i can see that the hardware for the sound is either not enabled... If it was it would show up in your Device manager with a yellow exclamation mark....
So first thing to do is the reset your BIOS to defaults... So once you boot back to Windows check to see if you can see any devices having exclamation marks under device manager.
Let me know then we can go to the next step..
Hello, sorry for late reply. I have tried what you said, but still I cannot see yellow exclamation marks under Device Manager.
AWARD_ , awardacpi
WinFast 760GXK8MC
2.00 GB
Maxtor 80gb
ESET NOD 32
Google chrome
Well like i said.. the system is pretty old ... and i have a feeling the CMOS battery is almost dead.
what you could do it look at he motherboard layout taken from you Manufacturer site
and look at the location of the CMOS reset jumper.. the follow the image below to see how to reset it .
Once this is done.. restart you system and check your device manager to see if you find anything under "Sound, video and Game Controllers"
Let me know how it goes
Hello, I tried what you said and with it, I got this now on my Device Manager, before I cannot see this:
It doesn't have Sound, Video and Game Controllers but only that.
AWARD_ , awardacpi
WinFast 760GXK8MC
2.00 GB
Maxtor 80gb
ESET NOD 32
Google chrome
well thats what i wanted to see !!
Now here is the problem.... Go to the manufacturer site under Tech Support.. you will see 2 audio drivers ... Now.. i am not sure if it has a Win 7 version as the motherboard is only supported till Win XP.... But you can give it a shot and download the audio driver that dated to 2007.
Install it and check and see if you see the sound driver under Device manager.
Also to note ... you need to buy a new CMOS battery and replace the old one on the motherboard.
Let me know how it goes.
Hello, about the CMOS battery, I don't know where I can buy and I don't know how to replace as well. But if I got time and money I will try to research on how to replace it.
I followed what you said and I downloaded the 2007 audio driver in the manufacturer site. And I run in on compatibility. Then it successfully installed, however, after restart, it told me "No ADI Codec installed" and still got red x mark in task bar tray. So I searched for google till I found this blog that the solution really worked for me:
http://www.bondysblog.co.uk/geek/windows-7-drivers-for-soundmax-adi-198x-fix/
So to other people that got same problems after installing SoundMax driver, they just have to follow your instructions then later on the instructions on the upper link.
Now I got this:
And my sounds is fully working now and I can party hehehe.
Thank you so much for helping me, especially the jumper thing, it really works. And it can be mark as solved now. <3 <3
More power to this forums.
AWARD_ , awardacpi
WinFast 760GXK8MC
2.00 GB
Maxtor 80gb
ESET NOD 32
Google chrome
the CMOS battery you could get them Watch shops ... these are round and flat... thats the only battery in motherboard...
Well good to hear it worked... The reason i was asking you to change the battery is that...if the CMOS battery is weak .. the setting in BIOS will not stay ...and you will have the same problem of no audio... So keep that in mind and get it changed asap.
Please do mark the thread as closed.. and REP those helped...
