Windows 7: New Realtek HD Audio Manager Driver Problem with Microphone
29 May 2013   #1
crazykilla
Windows 7 Ultimate 64-bit
Hello, I'm CrazyKilla
So I recently got a new motherboard and because it's a new board, it came with it's own audio drivers, and my old ones were useless (obviously). I installed these new audio drivers and i found that it changed the look (and most likely the software itself) of the Realtek HD Audio manager, before i got the new Manager, my microphone and audio both worked fine, now my audio still works fine, but my mic is messed up, when i talk, it doesn't pick it up, but if i blew air into the microphone, it picks it up but it is crackling, if i blew into the mic for 3/5 seconds then it would completely stop picking up the sound. Nothing happened to my mic during this process.
29 May 2013   #2
josearedux
Wow with a name like that I better get this correct ..Ha Ha Have you tried removing the Audio Mangler and using Windows drivers? Are you running the latest version from Realtek's site?
This may also be of some help Realtek HD Audio Manager Download
29 May 2013   #3
crazykilla
Audio Mangler? Windows Drivers? When I install windows fresh it has no audio drivers, i need to install manually from the motherboard disc or by downloading from the web. And when i tried uninstalling realtek and then installing drivers from the website, the MSI ones came back, strange.
02 Jun 2013   #4
crazykilla
So i found out there is no problem with the hardware, headset works fine with phone and when realtek is uninstalled, yes, i uninstalled realtek and used original windows drivers (I didn't know it had audio drivers by default since i've never used them). The mircophone works fine, so do all the cables, although when i use default audio drivers, i set it so whatever i say gets played back through the headphones, so i can hear my voice, although original windows drivers have like half a second delay, the last time i used realtek succesfully was when i had the Rampage IV Extreme board, which I don't know, might have better audio/microphone support or something and might not give a delay, or this might just be the default windows driver problem, can someone explain?
Difference between Realtek HD Audio Manager & Realtek HD Audio Driver
It's been a year since I migrated from Windows XP to Windows 7 which I downloaded Realtek HD Audio Manager R2.70 and audio has been working fine except the only issue it didn't come with 'Stereo Mix' preventing capability to record sound direct from the soundcard. It took me 14 months to restore...
Realtek driver installed, but no Audio Manager
Well, I'm doing a fresh Windows install and I'm having a little problem. With my old system, along with the Realtek driver install, came an Audio Manager (with nice features such as an equalizer). Now with my fresh install (different motherboard, but on-board realtek sound), I just installed the...
Drivers
Problem with realtek hd audio manager
Hello,everyone i have a problem with realtek hd audio manager.I installed the latest drivers and i dont have the audio manager i am working with Windows 7 Ultimate 64bit as the same i was working on my PC before,but now i am with laptop Acer TravelMate 5760G and i dont have the realtek manager,can...
Realtek HD Audio Manager Problem!
So, I have Realtek HD Audio Manager installed, and the latest drivers. My sound is now working fine, but my microphone isn't even being picked up. I don't know what kind of problem this is, but I was looking for help. My motherboard with on-board sound is a ECS Elitegroup GeForce7050m-m. Thanks for...
Realtek HD Audio Manager and Realtek Audio Driver
Help. I recently did a clean install of Windows 7 64bit (on my HP Vista 32 machine). Life is grand! My problems started when I tried to listen to the microphone input through my speakers. The front microphone inputs did not work so I downlaed the Realtek HD Audio Drivers (recently updated) from...
I have Realtek HD driver but no HD Audio Manager?
I have installed the latest drivers from the realtek website but I dont have this HD audtion manager (see attached)? Is this a separate install?
