Windows 7: 5.1 Sound Realtek HD Audio (5.1 works in settings, but not outside)
01 Jun 2013   #1
Tsuun
Windows 7 Home Premium
Hi 7foums!
A lot of people seem to have this problem, however no [solved] posts seemed to fix the problem.
_________________________________
Specs & Set up:
OS: Windows 7 Ultimate x64
Motherboard: ASUS M5A99X EVO R2.0
Driver: Realtek HD R2.71 (Driver version: 6.0.1.6873)
In order to achieve 5.1 sound, I have the rear speakers connected to rear speaker out (black), center/sub to center/sub out (yellow) and then the front speakers to Front speaker out (green), and none connected to side speaker out.
To the problem:
The surround sound works perfectly when testing with 5.1 in the Realtek HD audio manager, and also in the Sound configuration. However 5.1 doesnt work anywhere else, VLC, system sounds etc, instead the sound comes from the front speakers only. I've tried every setting in VLC, but since the 5.1 doesnt work anywhere outside of configuration I assume that the problem lies somewhere else.
The settings are set to 5.1 and through speakers are placed as default, all chords are connected, and as I wrote, the sound works perfectly when testing in settings.
Does anyone have any idea what the problem is?
Tomorrow I'm going to try and rollback the drivers, but if anyone else has an idea for what I can do, please give tips. Might it be a windows 7 update issue?
For what its worth, I don't see "Speaker fill" option when I go into Settings > Sound > Speaker Properties > Enhancements, this has been listed as a solution for this problem, but I can't find it.
Sorry for the disjointed descriptions and I hope that my predicament is comprehensible, my only excuse is that I'm incredibly tired.
01 Jun 2013   #2
Dude
Windows 10 Pro X64
Tsuun,
Are you using VLC for a specific reason? If everything works with your system check then it would seem you have a codec conflict. VLC is very good, and uses it's own codecs, but if you can play it without it then I would.
Is this a movie or audio file you are trying to play that does not work?
I ask because if you have working sound within windows, you can add codecs to continue using your default sound. I have used shark007 codec pack without any problems, plays all video and music files with not issue.
Shark Codec
01 Jun 2013   #3
Gary
Win 10 Pro 64
I have been using Shark for years. No problems. Just have to watch out when you install for the toolbar BS.
01 Jun 2013   #4
Dude
Windows 10 Pro X64
Thanks for adding that Gary, I always forget to mention that!
No sound from onboard audio (Realtek High Defition Audio)
Hey Guys, So here it goes, I normally have my Logitech z-5500 speakers connected to the onboard sound output (green,yellow and black) as well as my Plantronics 780 connected to the front panel USB port. I used to be able to play music through any one without any problems, just had to select...
Realtek HD audio manager interface not showing advanced settings
Thank's for looking. I have a Asus-G74sx-91234z laptop,last week when i plugged in headphone i started to hear sound coming from both headphone and the laptop speakers,a quick google search told me change some settings in Realtek HD audio manager,when i opened the user interface i found my realtek...
Realtek HD Audio EQ settings problem
Hello. :) i have a problem with Realtek Preset EQ when i change the EQ settings .. it works perfectly while playing a song but when i close the audioplayer and restart it again the EQ settings back to it's default so.. how can i save this settings and make it work everytime i lunch a media...
Cannot Realtek HD Audio Manager GUI/settings
After accidentally closing the HD Audio Manager from my taskbar a few days ago, my computer's audio stopped working entirely. So, after researching my problem online a bit, I checked in the Device Manager, and Realtek HD Audio was still installed as an audio driver. Taking the advice of another...
Realtek HD Audio Sound Comes and Goes
My sound comes and goes on my HP e9280t. Sometimes I get the realtek hd manager icon telling me that the speakers have been plugged in, and then 1 second later it tells me they have been unplugged. It can keep doing that for minutes until I finally close the message. If I go into the audio manager,...
Hardware & Devices
Realtek audio, no sound, need help!
I just installed Windows 7 on my Acer Aspire E380 desktop. I have tried downloading and installing newest drivers, and still am unable to get sound. I have tried uninstalling and reinstalling, still no sound. I have checked in device manager and everything says the driver is working properly. I...
