Windows 7: factory sound card VS SoundBlaster USB sound card
03 Jun 2013   #1
carputer93
windows 7
hello in my present setup i have a factory soundcard thats installed in my intel atom mini pc and i have a usb soundblaster laying around.. my question is it worth to swapp in the usb sound card or its not much of a difference using the built in sound card
my PC
Cheap Intel Atom Mini Pc Hi10c - Buy Cheap Mini Desktop Pc,Mini Pc,Intel Atom Mini Pc Product on Alibaba.com
sound card
http://www.newegg.com/Product/Produc...82E16829102020
03 Jun 2013   #2
fireberd
Windows 7/10 64 bit
As you have a USB connected SoundBlaster, disable the internal sound "card" in the BIOS and then connect and install the SoundBlaster and try it.
04 Jun 2013   #3
Dagens
Win7
Depends on your needs. If you want good sound quality - USB Soundblaster will be much better choice of course.
04 Jun 2013   #4
carputer93
windows 7
Well the reasoning is I have my PC connected to a 4 channel amp and usually after a hour of continued play my PC stops playing audio but wmp is still playing and I'm thinking if I add the sound blaster it might stop that from happening
06 Jun 2013   #5
fireberd
Windows 7/10 64 bit
Possibly. May be some other issue, but if the SoundBlaster does not cut out then that proves its a problem with the internal sound chip. However, if the SoundBlaster also cuts out, its back to the "drawing board" as its a PC problem (hardware or software).
06 Jun 2013   #6
carputer93
windows 7
Yes true the think is it will cut out I will close WMP open it back up again and it works ....the reason I asking rather than just plugging it up it. Is that the PC is installed under the dashboard and I have to get another screen (I already ) have because my main screen is a USB driven touch screen.I just wanted a would Anwser or personal reviews on what people think about the sound blaster before I take the car apart again
07 Jun 2013   #7
fireberd
Windows 7/10 64 bit
There are opinions both ways on whether the SoundBlaster's (mostly PC cards not USB) are better than the built in sound "cards" (chips). In the past the SB's were better. Modern built in sound has come a long ways and many equal the SB's.
My own opinion the USB SB is probably better than the built in, in the small Atom based mini laptops, but it may not fix the dropout problem.
07 Jun 2013   #8
carputer93
windows 7
So your saying in general because of how the computer was built I can't put a band aid on how it cuts off after a hour..
07 Jun 2013   #9
fireberd
Windows 7/10 64 bit
No, I'm not saying its the way it was built - the problem could happen in any PC. Just that a different sound "card" may not make a difference and there could be some other reason it cuts off (If it still does with the SoundBlaster I would look at the other programs that are loaded at start up and running, as potential causes).
I had a Samsung Netbook with an Atom CPU. It had limited memory (I think 2GB) which doesn't leave much memory for mutiple applications to run at the same time.
07 Jun 2013   #10
carputer93
windows 7
Well I Dont have any programs loaded. It has 1gb of ram. The usual function for this computer is just to play music .if its not turn all the way up it won't cut off . It may have programs running in the background that aren't being used but just load on start up.
S/PDIF Optical out - No sound from receiver (onboard and sound card)
I've got an Asus Crosshair V Formula motherboard that I couldn't get any sound on my Onkyo HT-R550 receiver via the onboard optical output (Win 7 Ultimate 64 bit OS) I was planning on getting a nicer sound card anyway, so I bought the Asus Xonar Essence ST. Installed that sound card but alas, I...
Distortion sound using onboard realtek sound card on windows 7ultimate
Hello,i recently upgrade my system from xp to windows7,i use the same realtek driver and get distortions!I try severall drivers,disable all enhancements/levels on speakers properties with no result(2.1speakers-),i configure them in stereo mode,i reduce the default format to 44100 16bits(cd...
My Thoughts on Creative's Soundblaster ZXR Sound Card
If you’re a serious music fan who listens to music on your PC, this is definitely a card to get! At around $200 bucks it isn’t cheap; but for those 200 bones you get an audiophile grade card with replaceable OP amps, a whopping 124DB signal to noise ratio, and a built in 600 ohm headphone amp for...
Creative Sound Blaster Audigy 24bit Sound Card
I installed windows 7 a little while ago but i cant seem to get a driver that will recognize my sound card. the computer doesnt think its installed correctly but when i was using Xp it was just fine. ive tried another PCI slot but no such luck. all of the drivers i have tried tell me that they dont...
Drivers
Soundblaster Sound card problem
Hi all, I have a problem ..... I installed a Creative Soundblaster X-Fi Titanium soundcard and now Windows media won't play soundfiles, it just says 'Windows Media Player encountered a problem'. It plays video files but without any sound. No other mp3 playing software works except for Adobe...
Hardware & Devices
FPS drop because of sound card / sound card drivers?
I've recently upgraded my os to windows 7, and noticed a significant fps drop in all games I've installed. The problem seems to come from the sound card. I've disabled it in device manager and I gained a steady 15-20 more in most of the applications. Any idea what to do? Is it a driver issue or...
Gaming
