Windows 7: NO sound Windows 7 32-bit using Realtek HD audio
15 Jun 2013   #11
mioemerchie
Windows 7 32 Bit
OK, I have a couple of questions just to clarify things.
What are you using to listen to the sound and where is it plugged in? headset, front panel also tried back panel
Is the BIOS setting for HD Audio/AC97 set to match the case plug that's connected to that header? i don't know what's the right settings but I tried switching settings, but fails to hear any sound.
In Control Panel > Sound, what is set as the default playback device? If you are using speakers or a headset you do not want it set to HDMI. its realtek hd audio.
I purchased a USB sound card (adapter) which converts my phone jack to USB, windows installed a generic USB sound card adapter still the same issue the sound meter is going up and down but I still hear no sound.
Tested the headset with my iPhone, its not busted cause I hear music.
15 Jun 2013   #12
mioemerchie
Windows 7 32 Bit
Operating System
Microsoft Windows 7 Ultimate 32-bit
Intel Core 2 Duo E4400 @ 2.00GHz 60 C
Conroe 65nm Technology
RAM
4.00GB Dual-Channel DDR2 @ 336MHz (5-5-5-15)
ASUSTeK Computer INC. P5KPL-AM SE (Socket 775) 47 C
Graphics
SyncMaster (1280x1024@60Hz)
1024MB GeForce 9400 GT (Undefined) 57 C <-- what does undefined here means 0.0
149GB SAMSUNG HD161HJ ATA Device (SATA) 37 C
Optical Drives
HL-DT-ST DVD-RAM GSA-H55L ATA Device
Audio
USB Audio Device
15 Jun 2013   #13
alphanumeric
Windows 10 Education 64 bit
15 Jun 2013   #14
mioemerchie
Windows 7 32 Bit
for now its generic USB Audio Device, since I'm using the USB adapter. Still no sound, output only the green indicator going up and down while I play audio file or go to youtube.
If I plugged directly to the ports, this system message comes up "The peripheral does not appear to be plugged in. Check the connection. Proceed to next step to finish." note* that my current BIOS setting is HD Audio.
If I restart the PC and change BIOS settings to AC'97, the computer will be able detect the audio device but no sound output, only the green indicator having sound activity but none that I can hear.
*** I installed the spyware removal and run system scan, it removed some adware and spyware but it didn't resolve the problem. And I didn't thought it would anyway xD
15 Jun 2013   #15
ICIT2LOL
Can I suggest an Asus Xonar D series sound card and just use normal jacks? the DG card is really inexpensive and has very good mixing and effects functions.
15 Jun 2013   #16
alphanumeric
Quote   Quote: Originally Posted by mioemerchie View Post
Like I said before, the BIOS setting has to match the plug on the front panel jacks cable. It sounds like it should be set to AC97 as it detects when in that setting. Double check to make sure your sound isn't set to "muted". The speaker icon in the task monitor down next to the clock should indicate this by a red circle with a red bar though it.
15 Jun 2013   #17
mioemerchie
Windows 7 32 Bit
its not muted and yeah its on AC'97.. still no sound. :-( Jeez I am Windows 7 MS tech and awarded best tech for the quarter and I can't solve this ... I am a douche :'(
15 Jun 2013   #18
alphanumeric
My guess, and it is only a guess, is that Magic Jack screwed something up even though you uninstalled it. If it was me I'd reinstall. The only other option that comes to mind is system restore.
15 Jun 2013   #19
mioemerchie
Windows 7 32 Bit
As much as I want to reinstall, I don't have the option. I hate to patch 3 of my online games (2-3 years patch). Dreadful
18 Jun 2013   #20
mioemerchie
Windows 7 32 Bit
BumP! Any bright ideas there....
No sound from onboard audio (Realtek High Defition Audio)
Hey Guys, So here it goes, I normally have my Logitech z-5500 speakers connected to the onboard sound output (green,yellow and black) as well as my Plantronics 780 connected to the front panel USB port. I used to be able to play music through any one without any problems, just had to select...
Realtek Audio Windows 7 No Sound
I just reinstalled windows and installed the latest realtek from here Realtek I checked my playback devices, and it shows a green bar going up and down indicating that the sound should be working, but i can't here jack. If i switch my sound in playback devices to my 42 inch flat screen,...
Windows shows an audio device but doesn't play any sound. (Realtek)
The past few days I found that I could no longer hear anything from my earphones when I plugged in my earphones.The problem first started when I started the computer without plugging the ram completely into its socket. After I plugged the ram back in, the bios said it restored itself to the default...
Sound Skippies on Windows 7 after installing Realtek HD audio
Guys, I have problem with Realtek HD audio when sound plays. The sound skippies on some areas. Please reply.
Record sound in windows 7 with realtek hd audio??
Hi, anybody know how to record sound with realtek hd audio?? I tried sound recorder in windows but no success?
Realtek HD Audio Sound Comes and Goes
My sound comes and goes on my HP e9280t. Sometimes I get the realtek hd manager icon telling me that the speakers have been plugged in, and then 1 second later it tells me they have been unplugged. It can keep doing that for minutes until I finally close the message. If I go into the audio manager,...
Hardware & Devices
