Windows 7: NO sound Windows 7 32-bit using Realtek HD audio
05 Jun 2013   #1
mioemerchie
Windows 7 32 Bit
Hi everyone,
I am having issues with my sound(built in) and has been trying to fix this for over 6 months now.
Here are the details of the problem:
No sound after installing Windows 7 32 bit Ultimate or probably after installing the NVIDIA 9400 GT Video Card
still using VGA as my monitor only supports VGA.
BIOS:
Shows Azalia in Southbridge Audio Controller
Below that it shows HD Audio ( If set to this -- error in windows is "no device is plugged in")
If I change HD Audio to AC 97 (Windows will be able to detect my headset but no sound output)
Windows Environment:
AC'97 (bios setting)
Under playback the green bar is showing activity as I play an audio file, yet no audio output.
I checked Device Manager and driver installed is Realtek HD Audio (Supplied by Windows 7 same as the 9400GT drivers which was automatically supplied by Windows 7 upon installation.
Steps Taken:
1.) Try to uninstall the VC to isolate problem still no sound
2.) Uninstall and reinstall Audio Driver no sound
3.) Updated drivers ( Windows has the most updated driver)
4.) Manual update still no progress
5.) Tried install AC'97 Realtek ( test build so to install the drivers ) still shows HD Audio
6.) Used Driver Max to update drivers still nothing.
7.) I have magic jack (USB) and when I play a game while someone is using the phone, there is sound output on the handset.
8.) Updated Nvidia drivers still no sound
9.) CHeck headset and it works with my laptop
10.)Tried connecting to back panel still no sound
I was planning to buy a USB headset or a jack-USB converter but it's expensive and the jack-USB is nowhere to be found.
PLEASE advise if you have any suggestion... thanks!
Karl
05 Jun 2013   #2
ICIT2LOL
Hello and welcome Karl mate as a general rule I like to download drivers from the manufacturers in preference to Windows information.
I would try the audio and chipset drivers from here if you haven't done them already.
P5KPL SE - Motherboards - ASUS
07 Jun 2013   #3
mioemerchie
Windows 7 32 Bit
I have already done that as well, sorry for not including it in my post. I tried to redownload and install from the link you posted but still the same issue
07 Jun 2013   #4
Mark Phelps
Sorry, but this is a wild guess ... I don't use MagicJack, but my guess is that if you had to "install" it, it redirected the audio output to "itself" and thus, now, you don't get audio through the previous outputs.
I'm only saying this because I've seen other thread where folks installed new USB devices and suddenly, their audio didn't work like it did before.
You could try uninstalling MagicJack -- just to see if that changes anything.
08 Jun 2013   #5
mioemerchie
Windows 7 32 Bit
I just uninstalled Magic Jack and rebooted my computer. The issue still persist, I am guessing HDMI driver is messing with my audio? however, in device manager there is no hdmi audio driver under audio and sounds.
08 Jun 2013   #6
ICIT2LOL
Hum well I have never really seen a driver for HDMI as such I would have thought the outputs would have been included in the chipset or audio drivers but as your board has no HDMI output it has to be with your GPU as it has the HDMI output maybe you need to redo the drivers for it?
09 Jun 2013   #7
alphanumeric
Windows 10 Education 64 bit
The BIOS setting for "HD Audio" or "AC 97" is for matching your case front panel audio jacks to the motherboard header. The cable that connects to the case front panel audio jacks will have a plug labeled HD Audio or AC97, it may also have two plugs, one of each. Only one can be connected and the BIOS setting has to match what plug is connected. Also make sure you don't have the plug reversed. To the best of my knowledge this BIOS setting has no effect on the back panel audio jacks.
One thing to check is to go to Sound in control panel and make sure the correct device is selected under the Playback tab.
12 Jun 2013   #8
mioemerchie
Windows 7 32 Bit
Still not working, after changing the settings back and fourth I tried uninstalling the drivers for the the GPU but still there is no sound. This quite mind boggling... any other suggestions?
12 Jun 2013   #9
alphanumeric
OK, I have a couple of questions just to clarify things.
What are you using to listen to the sound and where is it plugged in?
Is the BIOS setting for HD Audio/AC97 set to match the case plug that's connected to that header?
In Control Panel > Sound, what is set as the default playback device? If you are using speakers or a headset you do not want it set to HDMI.
I'm thinking the HDMI driver is part of the Video Driver.
12 Jun 2013   #10
ICIT2LOL
Quote   Quote: Originally Posted by alphanumeric View Post
Agreed Alpha it is http://www.geforce.com/hardware/desktop-gpus/geforce-9400-gt/specifications so maybe the card is bung! I do notice too that there is no security on this machine and I would a suggest at least a sweep with these would not go amiss.
http://www.superantispyware.com/
http://www.malwarebytes.org/products/malwarebytes_free/
http://www.bleepingcomputer.com/download/adwcleaner/
download ADW from bleeping computer
plus I would be looking at the temps and the PSU volts
Speccy - Download
PSU - http://www.sevenforums.com/vip/257690-psu-how-test.html#post2130086
No sound from onboard audio (Realtek High Defition Audio)
Hey Guys, So here it goes, I normally have my Logitech z-5500 speakers connected to the onboard sound output (green,yellow and black) as well as my Plantronics 780 connected to the front panel USB port. I used to be able to play music through any one without any problems, just had to select...
Realtek Audio Windows 7 No Sound
I just reinstalled windows and installed the latest realtek from here Realtek I checked my playback devices, and it shows a green bar going up and down indicating that the sound should be working, but i can't here jack. If i switch my sound in playback devices to my 42 inch flat screen,...
Windows shows an audio device but doesn't play any sound. (Realtek)
The past few days I found that I could no longer hear anything from my earphones when I plugged in my earphones.The problem first started when I started the computer without plugging the ram completely into its socket. After I plugged the ram back in, the bios said it restored itself to the default...
Sound Skippies on Windows 7 after installing Realtek HD audio
Guys, I have problem with Realtek HD audio when sound plays. The sound skippies on some areas. Please reply.
Record sound in windows 7 with realtek hd audio??
Hi, anybody know how to record sound with realtek hd audio?? I tried sound recorder in windows but no success?
Realtek HD Audio Sound Comes and Goes
My sound comes and goes on my HP e9280t. Sometimes I get the realtek hd manager icon telling me that the speakers have been plugged in, and then 1 second later it tells me they have been unplugged. It can keep doing that for minutes until I finally close the message. If I go into the audio manager,...
Hardware & Devices
