Windows 7: My sound is going through PC instead of the MIC with headset
05 Jun 2013   #1
xzero1134
Windows Home Premium
So i've been browsing forums for a while now and can't find out what's going on. I have a sound card with Realtek HD Audio. Recently, I connected a PCIM cord to my motherboard so I can have sound on an HDTV, which works fine. SINCE then, this problem started. The front ports for MIC and sound don't work at all, I don't get an "audio device detected" message. If i plug my headset MIc and Sound into the back of the PC, i hear the sound but so does everyone else instead of my Voice. I can tell this i whats happening because when I right click on recording options i see the bars on the mic moving with my sounds. Now if I unplug the sound portion and leave the MIC in, it does pick up my voice as normal. I can even plug in my speakers and they will play sound and it will work that way. not really ideal for a headset however, I'm not sure what setting to change or what to do to get this to work. Also the headset does not show up in playback devices, i have show hidden and unused checked. I tried to update my drivers but when I try to install them windows gives me a "untrsuted" pop-p that re-appears not matter how many times I select allow. any ideas?
06 Jun 2013   #2
fireberd
When you are using HDMI, that becomes the defaul audio playback device. In order for the PC sound system (including headphones) to work or properly work the "Speakers" (your sound card) must be set as the default audio playback device.
Windows only allows you to have one default audio playback device, e.g. HDMI OR Speakers but not both.
07 Jun 2013   #3
xzero1134
I did manage to fix the front jack issue, but the pc isntead of mic problems persists. I do have 2 different devices i have swithc between speakers and "digital output" if I want to use my TV. picking either as default doesnt fix the issue.
No sound when headset is plugged in
Hello all, I am on laptop using Windows 7 home premium 64bit. There is sound when nothing is plugged into the audio jack, but when something is plugged, there is no sound. I am using also Kubuntu on the same laptop, and the sound works perfectly even when a headset is plugged in the audio...
How To Amplify Sound from Siberia V2 Headset
Hey guys! I have a Siberia V2 Headset w/ a built in soundcard. The headset itself has a volume slider which is good because I don't have to open the volume settings or touch my computer to change the volume, but the output sound is very quiet. I have to have the volume on 100 and then adjust the...
uncontrollable sound when using 2-usb pnp headset
Hi all, I have a new custom computer since one year (description bellow) for which I have a 2-usb pnp sound device (headset: steelseries 3H). Since the beginning the sound in the headset is really absolutly high. I need to put the overall sound of my computer (via volume mixer) to about 2 to...
BSOD Help and Support
No Sound Coming out from Bluetooth Headset
Hi, I purchased a china-made Bluetooth headset that works perfectly on my phone, on my netbook (Dell Inspiron Mini - Windows 7 Starter) and my office laptop (HP Compaq running on Win XP). The problem is that it is not working on my other HP laptop (HP Compaq 6730B), wherein I really intended to...
Drivers
No sound from bluetooth headset
Win7 sees my bluetooth device. It shows the services as available and (via checkmarks in the boxes) selected for use. But my headset never shows up in the Playback devices and no sound comes through the headset. Any ideas?
