Windows 7: Front mic panel not working, "not plugged in"
05 Jun 2013   #1
scythe713
Win7 Ultimate x64
Ok im at wits end! Im pretty sure i got this to work before. But i forgot how to do it. My front mic panel doesnt work ive spent hours trying to find the solution but failed
The front panel used to work before so im sure it shouldnt be a hardware issue. About six months ago i was tweeking the settings and somehow managed to make the back panel the default, but that disabled the front port, i didnt care at the time coz i didnt need it. I want my speakers hooked up to the back panel while my headset and mic to be hooked up to the front panels. My problem is that it keeps telling me that the mic is not plugged in even though it is, and yes the mic and earphones are plugged in the right place. Any tips on what i need to do? Ive already reinstalled the motherboard OS if that helps.
This is a pic of my recording settings.
Also the front earphone slot was working yesterday while the mic wasnt, but i tweeked with it too much and now both the earphone slot and the mic slot have stopped working.
06 Jun 2013   #2
bobafetthotmail
Win 7 Pro 64-bit 7601
What you mean for motherboard OS?
Try going in your BIOS settings (during boot press a key like F2 or Del, it should tell you what key to press to enter Setup in the white text) and look for audio settings in its panels.
If that does not work I'd try uninstalling the audio drivers and reinstalling them again.
Go here, download the most recent file in the "AUDIO" category, then go to Device Manager (write "device manager" in the Start menu searchbox) and then look in the category "sound, video and game controllers" to find your audio device, double click on it and in the new panel select the Driver tab, then select "uninstall", and then tick the box about deleting the driver. Close all these panels.
Then go in Programs and features (again Start searchbox if you cannot find it), and look for your audio utilities, and uninstall them.
Then reboot (power down and power up) and install the drivers (and probably utilities) that are in the package you downloaded a few lines above.
29 Apr 2015   #3
Sylveon Fetish
Windows 7 Ultimate 64-bit SP1
I have same problem and from the looks of this. this is unresolved. can someone help me with the same problem?
29 Apr 2015   #4
fireberd
Is you problem EXACTLY like the one listed or just that your mic is not recognized?
More specific info would help, and you should have started a new thread for your problem.
Two things I note from your "My System Specs". First if you only have the High Definition Audio Device drivers, that says you do not have the driver for the actual sound hardware, that is only a Windows installed generic, basic function driver. Install the correct driver from HP and see if that makes a difference.
Second, you list Win 7 Ultimate 64 bit OS. With only 4 GB of RAM you should be using the 32 bit version. The main reason for using a 64 bit OS is that it will use (address) more than 4 GB of RAM. In fact, a 64 bit OS uses more of the basic memory than the 32 bit version does, thus leaving you less for programs.
04 May 2015   #5
Sylveon Fetish
Hp doesn't provide 32 bit drivers for my computer. It only has drivers for 64-bit Windows 8, and 64-bit Windows 7. None other. The 64-bit drivers don't install on a 32-bit machine. Soundcard is a Realtek HD Audio. I installed the drivers from the Hp website and still not work. I think my computer mistakens my microphone for headphones because there is no sound from the speakers when I plug my microphone in.
My problem might be more related to my post here
Quote   Quote: Originally Posted by Sylveon Fetish View Post
I am having the same problem on my laptop. Same realtek hd audio and everything. Nothing here has helped. My computer recognizes my microphone as headphones as well, I have no option to disable the jack. Any other ideas you may give?
Front Usb Panel Not Working.
Sir, Motherboard - Asus P5g41t-MLX Last week i changed my cpu cabinet. Done the installation. But, after installation, i have some problem with the cabinet's front usb ports & audio ports. The motherboard have 4 usb ports & 3 audio ports (rose,green.blue) at the back side. All these are working...
Hardware & Devices
When I open "My Computer" or "Control Panel" nothing displays.
Hello everyone, I've run into an issue that I can't seem to find answer to on the net. When I open My Computer, Control Panel or any folder no files or directories display, after first there is a green loading bar on the address bar and little magnifying glasses (searching icon) on the...
Hardware & Devices
"Windows Control Panel has stopped working" on My Computer Properties
Hi I am running Windows 7 Pro 64-bit on a Lenovo T510. Every single time I do a Properties on My Computer, I get this pop up message that "Windows Control Panel has stopped working". Oddly, I just cancel that window and everything otherwise seems to work normally. But it happens every time...
General Discussion
Google "More" and "Search Tools" buttons no longer working...
Sometime over the last few weeks Google's "More" drop-down and its "Search Tools" menu items have quit working in IE10. The other buttons that let you select web, images, shopping, etc. still work properly. The "More" and "Search Tools" buttons get focus when the mouse is over them and they...
Browsers & Mail
Connecting "HD audio" cable from front panel to sound card
My sound card Xonar D1 doesn't work properly and i wrote to ASUS and they told me to connect the "HD audio" or "speaker" cables from the front panel of motherboard to the sound card's front panel. Is that safe to do? weather it will work or not, is it safe to try?
Need help and advice "front panel/sound"
My 3rd logitech usb headset conked out today. The stupid things literally have a lifetime of about 3 months before they short out and quit working in one ear... So I started looking around at my replacement choices, needless to say that my choices are severely lacking. But here are my...
Hardware & Devices
