Windows 7: Win 7 audio balance not working. Help!
06 Jun 2013   #1
camoguy
Hello, I'm having a slight problem with my audio balancing atm. I've been sick recently and fluid has entered my right ear, so i have to move some audio over to it, which is proving extremely hard because:
  • when i move the left channel volume down, the right channel volume follows it.
  • I have no external audio programs running.
I am currently using a Gigabyte Tech Co. Mobo, and my headphones are plugged in via optical jack. (Same problem occurs with 3.5 to 3.5 jacks)
I have also done a search for updated audio drivers. Many times.
06 Jun 2013   #2
camoguy
I found a temporary fix. There was an application hiding in my task manager that i disabled and turned off. Now i can balance properly, but it comes back every reboot.
Realtek audio, Gigabyte mobo: strange-sounding audio, mic not working
I have a self-assembled desktop PC - full specs in the signature below, but in short, it has an AMD Phenom II X6 1090T processor on a Gigabyte GA-970A-DS3P mainboard, which uses a Realtek Azalia ALC887 on-board sound system. I have no loudspeakers and listen to the computer sound exclusively...
Win7 realtek audio balance not working
Hello, im using Windows 7 64bit Motherboard Name Intel Whitesburg DP55WB Realtek ALC888/1200 @ Intel Ibex Peak PCH - High Definition Audio Controller PCI Headphones steelseries syberia v2 - 3.5mm jack this is integrated sound card so my problem is, what not working balance. then I...
Audio Jack not working, but USB Audio is.
My self built computer recently had a change of motherboard, I now have a Asrock N68C-GS FX. The front cases' and computers back audio jack are not working, I have tried numerous headphones and speakers. However my USB headset works perfectly. My drivers are all up to date, I'm struggling to...
Asus onboard audio no longer working since enabling front panel audio.
My audio rear outs used to work, but even so, i was primarily using hdmi out from my video card. I was also diagnosing BSODs at the time and sent my mobo back to asus for an rma. When it got back, I placed it in a different case and attached the font panel audio. Due to a new living...
How to auto-change audio balance with multiple screens
Hey, I just upgraded to three screens on my desktop. I have a full surround sound speaker system using a Sewell external audio card. Is it possible to have the audio balance change to the left and right depending upon which screen something is playing on? I'm guessing this is a difficult...
Onboard audio not working and audio drivers won't install
Hello everyone, I'm having a problem using my motherboardís onboard HD audio instead of my video cardís audio, so without further ado here is the situation; I have an Asus maximus iii gene motherboard which has a SupremeFX X-Fi built-in sound card (this is a very nice card provided you can...
