Windows 7: Sound through headphones not working after sleep
11 Jun 2013   #1
Xenia
Windows 7 Home Premium 64 bit
I have recently updated my realtek audio drivers to the latest version on my acer laptop.
But now after my computer comes out of sleep mode, I can't hear anything trough my headphones. When I unplug them, the sound is just fine. I have line in headphones, not USB.
The only way to get them back working is to restart my computer.
I don't know if it is because of the new driver, but it happend after the install.
How can i fix this ?
Thanks in advance
11 Jun 2013   #2
fireberd
Did you install an Acer supplied driver, specific for your Laptop model, or did you install the generice RealTek drivers from RealTek? In most cases the PC vendor (Acer in this case) drivers are the preferred drivers. Generic drivers, such as the ones on the RealTek downloads may or may not work properly. RealTek has a warning on their downloads to use the Vendor supplied (if available).
12 Jun 2013   #3
Xenia
When I bought the laptop is had already a realtek audio driver, so i just updated it.
I searched the site for an acer audio driver for my model, but they don't have it
12 Jun 2013   #4
CBlunt
Windows 8 64bit
Sounds like Power Options to me. Change them so your computer never goes to sleep, that should solve your problem.
12 Jun 2013   #5
Barman58
Windows 10 Pro x64 x2 Windows 10 Enterprise x64, Ubuntu
The realtek drivers sometimes have an option (fairly deeply buried in the options), to ignore the status of the headphone socket, may be worth checking if this has been set on by the driver update - a long shot but worth a look.
Otherwise you may want to roll back the driver to the one that worked, unless the update cured other more critical issues, of course
12 Jun 2013   #6
fireberd
With an i7, as your system specs indicate, it is a new model and Acer should have a sound driver for that PC. If its a different model, please list the actual PC model number, all we are doing is guessing without it.
But, I agree on rolling back the driver to the one that worked. Unless there was a problem with the old driver and the new one fixed it the old adage applies "if it ain't broke, don't fix it"..
29 Aug 2016   #7
yozi
Windows 7 Pro x64
Workaround
For me, the problem appears when my notebook enters sleep mode with the headphones plugged in.
Workaround: remove the headphones, enter sleep mode and wake up.
After this, the headphones work again.
My notebook is Lenovo L430 with Realtek ALC3232 audio (and Windows 7 Pro x64).
Others say that bios update could solve the problem.
No sound in headphones
I have Windows 7 64 bit and when I boot up windows without headphones plugged in, the sound works fine through the speakers but when I plug in the headphones they do not work. If I unplug the headphones, the sound starts coming out of the speakers. I have tried manually switching devices but that...
Mic not working while using Steelseries usb sound card and headphones
Hello, I decided to make a post here since I'm losing my mind and I hope somebody will be able to help me. Yesterday I've got my hands on Siberia USB soundcard, one like this: SteelSeries - Gaming Headsets - SteelSeries Siberia USB Soundcard I'm currently using headset made by the same company:...
No sound through PC speakers but headphones working - Acer Aspire 5336
i am using win7 ultimate. i am hearing very little or no sound via my PC speakers. however, i can hear sound via headphones. checked all possible setting as per my knowledge. kindly someone help. The point to note here is that sound is working perfectly OK in Ubuntu 11.10. so my speakers...
Two headphones different sound for each headphones?
Hello, In my computer i had plugged in two headphones. One is for my brother, and one is for me. So sometimes we used to hear speeches,music etc... at same time. But sometimes i could feel to play football games. And its sounds will be disturbance for him. So any solution for this?
No sound from built in speakers, but sound from headphones
I have a Lenovo S10-3 Netbook, running on Win7 starter. It has been running fine unil a few days ago, when the built in speakers no longer play any sound. Works fine with earphones or exernal speakers, but not internal speakers. Drivers are all up to date, and audio/sound settings are all...
No sound through 5.1s... only headphones
Hi guys, I just built my new computer (Gigabyte mobo p55-ud3r + 4gb Ram + i5), but I can't get the sound working with my old 5.1 speakers, which worked fine on vista before. Thing is, when I connect my headphones, the sound works. Should there be a difference? I can't even check to see if...
