Sound only coming from left speaker
  1. Posts : 2
    Windows 7 Ultimate x32
    Yesterday the jack got misplaced so, I placed it again like it should be and then i noticed that the sound only came out from the left speaker. So I tried using earphones and it was also the same. Then I remembered that I can put my earphone jack in my controller (GEMBIRD JPD-FFB-A), so I plugged in my controller and then my earphones in the controller and it was still the same.
    Please help...
    What do you mean by that? If you translated to English, something got missed in the translation.
  3. Posts : 2
    I meant that it loosened up a bit (it was not fully plugged in), and because something is damaged i had to rotate it so that the sound would be normal
  4. Posts : 8,135
    Uninstall the sound, in the Device Manager. DO NOT uninstall the drivers. Restart the PC and when Windows starts it will detect and reinstall the sound. This MAY fix it.
