Sound Problem with new install Win 7 64 bit
My Soundcard will not properly in Win 7 64 bit. Although I (think) I have the right drivers and device manager says All OK the sound is crackly and very distorted.
Soundcard is a Soundblaster X-Fi SB0730. It works perfectly in Win XP and I also Win 7 32 bit (which I installed temporarily for a sound test). The motherboard is Gigabyte GA-M56S-S3.
All the Win 7 Updates have been installed.
The drivers I have tried are
SBXF_PCDRV_LB_2_18_0015
SBXF_PCDRV_L11_2_18_0015A
Results were identical for both, except the 'A' one flashed up this message twice
Loading of MUI Resource failed
The application will exit.
I have tried both with and without compatible mode ticked in the driver setup, but unsure if this sets the mode for the driver, or just the install program. I can find no way to set that mode for the driver. A Google search brought up something saying compatible mode is needed.
Creative won't help as it is OEM product, and Microsoft said they'd get back to me but haven't for over two weeks.
Thanks for any help.
