Windows 7: Is it possible to change from IDT Audio to Realtek Audio?
24 Jun 2013   #1
Nathan02
Windows 7 Home Premium 64-bit
I'm currently using IDT audio on my laptop, and I'm wondering if I could change the audio to Realtek. I also noticed Realtek PCIE Card Reader and Realtek Ethernet Controller Driver in the Programs and Features list. Why do I have Realtek products when I have IDT audio?
Can I change from IDT to Realtek?
I have an HP Pavilion dv6-6c35dx. If there's anything else you need to know, let me know. Thanks
24 Jun 2013   #2
gldndragn
Windows 7 Home Premium (64 bit)
No, the IDT chip is soldered to the motherboard, and cannot be changed.
The manufacturer has many options available to them when they design the computer. (such as network chip, sound chip, and others)
The IDT will/should work just fine for your system.
Realtek audio, Gigabyte mobo: strange-sounding audio, mic not working
I have a self-assembled desktop PC - full specs in the signature below, but in short, it has an AMD Phenom II X6 1090T processor on a Gigabyte GA-970A-DS3P mainboard, which uses a Realtek Azalia ALC887 on-board sound system. I have no loudspeakers and listen to the computer sound exclusively...
How does one change the kbps speed in RealTek Audio Manager?
How does one change the kbps speed in RealTek Audio Manager? I have this setup: Win 7 Home Premium 64bit, I5, 6GB RAM, and RealTek HD Audio Manager: Audio Driver Version:6.0.1.6586 DirectX Version:DirectX 11.0 Audio Controller:HD Audio Audio Codec:ALC892 This is what I'm doing:
Difference between Realtek HD Audio Manager & Realtek HD Audio Driver
It's been a year since I migrated from Windows XP to Windows 7 which I downloaded Realtek HD Audio Manager R2.70 and audio has been working fine except the only issue it didn't come with 'Stereo Mix' preventing capability to record sound direct from the soundcard. It took me 14 months to restore...
Realtek ALC889 audio, audio fine on S/PDIF, nothing from rear output
I'm having a strange problem in my HTPC. Audio is coming perfectly fine out from the S/PDIF coaxial output, and it's normally connected only that way to the receiver, but now for other reasons I also need to connect it using a 3.5 mm to a small mixer. So in the sound manager I changed the output to...
Audio Playback (Default Device Realtek) Knocks Out SRS Audio Sandbox
Hi, I finally upgraded from Windows XP to Windows 7 and almost went back shortly after finding out I could no longer organize or manually arrange my own personal files and/or folders but luckily I discovered an application called 'Folder Options X' which has re-enabled that feature for me so I'm...
change audio device from realtek
hi guys i need to change my audio devise from realtek to something else (windows/other) im using windows 7 and when every i go to play a game the pc freezes ive found out that its something to do with realtek because if i disable all sound the game works fine just no sound can you tell my how to do...
