Windows 7: Sound from computer and from monitor help!
25 Jun 2013   #1
RunOrDie
Hello everyone,
I am wondering how I can get sound from my computer and from my monitor while attached to HDMI.
Currently, I have my speakers connected to my computer. But I also have my PS3 connected to my monitor as well. How can I get sound to play from my monitor when I am using my PS3 (of course I will use either PS3 or PC, not both at the same time).
I just don't want to keep unplugging my speaker cord and inserting into my monitor..too annoying and time consuming.
Thanks in advance!
25 Jun 2013   #2
fireberd
You can only have one default audio playback device, either "Speakers" (PC audio) or HDMI, but not both at the same time. On most PC's when an HDMI cable is connected to the PC it will automatically switch the sound to HDMI. It can be manually changed in the Sound Panel/Playback section.
I don't know if this answers your question or not???
Nothing shows on monitor after start computer / 2 monitor Win7 desktop
My old Windows 7 desktop sounds normal on booting up but I can't see anything on the monitor. I may not have the monitor connected properly. A couple of years ago I bought a used corporate desktop PC with Windows 7 and used it for a while. Then I bought a new laptop and I haven't used the...
General Discussion
My Computer monitor doesn't show anything when I turn my computer on.
First of, my monitor exhibited signs of flickering during start-up, but only minor ones and would just stop at the 'Welcome' screen of windows so I didn't give it much thought. Iv'e been using it with the cpu the same time I bought the monitor. But after some time, the flickering got worse. It...
Graphic Cards
Anyway to get sound per display/monitor?
I have 2 displays, 1 is a TV 3 meters away hooked up to my graphics card via HDMI and the other other is obviously my PC monitor. I was hoping there would be a way to have sound exclusively on the TV while I have seperate audio on my monitor? Sorry it's a bit hard to explain. Basically I want to...
Play sound through monitor
I would like to have my computer play sound through the speakers which are plugged into the sound card if there is nothing plugged into the audio output on my monitor. That means that when I plug my headphones into my monitor, I want the sound to go from my speakers to my headphones. I'm...
Getting Sound Out Of Monitor
I have a magnavox hd tv monitor that i just hooked up to a new hp pavilion elite HPE. The external speakers work but the internal speakers on the monitor produce no sound. can't understand why the speakers on the monitor don't work. why do i have to use external speakers to get sound?
How do you get sound to come out of second monitor?
I connected my laptop to my monitor with a vga cable (since thats the only connector that the laptop has), but for some reason, sound is not coming out of the monitor. how should i fix this? i know that the speakers work, since i once got sound out of them, but have never used the speakers since ...
