Windows 7: Why must Audio be turned up using HDMI from TV set-top box
25 Jun 2013   #1
robert808
windows 7 home premium 64 bit SP1
I connect my Win 7 computer to set top box via HDMI to display TV. The problem is I must turn the volume way up to hear TV. But when going back to regular computer use the volume is way too loud and must turn it down. And if an audio email (MS Office Outlook) notification happens while on HDMI TV the whole neighborhood can hear it because it is so loud.
25 Jun 2013   #2
landi166
windows 7 ultimate 32bit
You could try to adjust (increase) the volume from your set-box .
25 Jun 2013   #3
robert808
The TV audio volume is controlled by the computer. the set top box has no volume control.
26 Jun 2013   #4
bobafetthotmail
Win 7 Pro 64-bit 7601
click on the speaker icon in the system tray of the PC, select "mixer", then you can adjust volumes for various different things. Like keeping system sounds down while speaker general volume up.
26 Jun 2013   #5
Solarstarshines
Quote   Quote: Originally Posted by robert808 View Post
HDMI though any device requires the other main device to be disabled as in if you are using onboard sound Disable it
Then let your TV be the default sound it would show up in audio as default device or even the dropbox select that as main audio and it should override the onboard thus bringing the true volume
Realtek HDMI Output ATI HDMI Audio -Not Plugged In-
I'm trying to hook up my TV with my computer, and for the most part it's working. The video goes through and I get how to control it and everything. The only thing not working is the sound. I'm using an HDMI to HDMI cable, and like I said the video is fine. Also, when the cable is plugged into...
No HDMI audio after running Win 7 audio trouble shooter
I have an Acer Aspire Laptop 57362-4790 running Win 7 with all the latest updates. Audio is an Intel(R) High Definition Audio HDMI, and Realteck HDMI. Because I had no headphone output with the computer connected to my TV via the HDMI out I ran the Windows audio trouble shooter. I got a...
No Audio, HDMI (unplugged), No Audio device listed
Hi, I just got a new (cascaded) computer with seemingly no standard audio. The audio icon is a speaker with and X through it and the only audio device that populates the Playback Devices list is the HDMI digital audio. I have audio on the motherboard (think I can find it?? nope) and...
HDMI audio problem when connecting LCD TV to PC via HDMI
hi all, I have my media center PC connected to a Sansung LCD TV through an HDMI cable. Everything works fine; the PC detects TV and both audio and video travel through the HDMI cable from PC to TV The problem happens when I turn the TV OFF and ON. In this case, the video is back but not the...
Windows 7 - HDMI out no audio - Intel HDMI audio
Hey everyone, I recently upgraded to Windows 7 (Build 7100) from Vista (32 bit) and am having trouble getting audio from my HDMI out port. I am using the Mobile Intel 965 Express Chipset and have upgraded to the latest available driver but still no luck. I have attached a screen shot of my...
Automatically switch display w. HDMI device turned on?
First situation now: I'm using a three display system where all displays are always connected but only max two can be used at the same time (see specs). Displays 1 and 2 are monitors, display 3 is a FullHD TV. I'm normally using 1 and 2. Display 3 is in my bedroom upstairs, connected with 15...
Graphic Cards
