Windows 7: Experiencing problem with sound on MPC
27 Jun 2013   #1
lordaethis
Last night i attached my laptop to to my HD tv Via HDMI cable to watch something. I was using media player classic. After film finished i disconnected cable. This morning i went to use media player classic and there was no sound, still have sound with other media software. Sound works if i plug it back into my TV.
I followed this FAQ - Media Player Classic
sound works on the stage 4 then followed to the end and sounds stops working please could i get some help as i use media player daily
28 Jun 2013   #2
fireberd
Use the System Restore function and restore the PC back to an available restore date when it did work correctly. See if that fixes it.
28 Jun 2013   #3
lordaethis
Just tried system restore it didnt fix it
additional information it use of headphones does not work either and sound work if i plug hdmi caple back in to tv
28 Jun 2013   #4
fireberd
Go to the Device Manager, RIGHT click on the entry for your PC sound card to highlight it. Then LEFT click "Uninstall". DO NOT uninstall the drivers. Restart the PC and when Windows starts it will detect and reinstall the sound. IF there were a corruption or conflict between the sound and Windows this will fix it.
Experiencing (Very) Low Sound Output on ASUS A8He
Hello, members of Seven Forums! Well, I upgraded my laptop's operating system from Windows XP (Professional) to Windows 7 (Ultimate) on November 2013. The experience was great except for frequent slowdowns, but I guess I'll get used to it. Going to the query: I use a VoIP software called...
Sound problem perrsists even after new sound card
As some of you might remember, a few weeks ago I had a problem with sound after I built a new PC and kept my old Win 7 installation using sysprep: http://www.sevenforums.com/sound-audio/280175-onboard-sound-issue-new-pc-build-2.html#post2308990. The problem was that the volume levels were off, and...
Experiencing Various BSODs while Idle
Hello, I have been experiencing various BSODs over the past month on my computer, which I only built this January. They mostly happen while my computer is idle, but occasionally they occur while I am doing general activities, like browsing folders or the Internet. Recently I've seen them while...
BSOD Help and Support
Sound problem - need to 'scan for hardware changes' to get sound
Hi everybody I have a fairly strange problem with my Laptop. It came originally with Vista and a while ago I updated to Windows 7 32bit Home Premium. Since then I don't have any sound after booting the Laptop. By chance I found out that when I go into the device manager, right click on the sound...
Hardware & Devices
Frequently experiencing BSOD
Am frequently experiencing BSOD on Windows 7. It mostly occurs when my laptop goes into standby mode. Attached herewith is the crashdump. Can someone please analyze it and suggest a solution?
Experiencing a few problems.
I am experiencing a few problems. I'm trying to optimize performance to where it loads fast and doesn't hybernate as much. I'm trying to get it to where i can add spacers between the docked items. Any idea how to accomplish these tasks?
Performance & Maintenance
