Windows 7: DFX Audio Enhancer - best audio enhancer on the market
28 Jun 2013   #1
lmao4u
Win7 Home Premium SP1
FxSound has this little driver called DFX Audio Enhancer, its free, however they have a pro-version as well.
I can say that my laptops audio output went from "ehhh" to OMFG and that is the truth.
I am new here and asking for help, so the least I can do is share back to the community as well.
Warning, do not set the options to full throttle for your tiny laptop speakers, you will most likely blow them clean out of the laptop and into outer space.
It does a very wonderful job of making those tiny speakers preform much better though, just don't full throttle it.
I have a set of regular external JBL Platinum speakers for a computer of some sort, (they have two hooks which I assume attach to a monitor).
I got them at the salvation army store for $1.99
With DFX on, I am always being told to turn down my music.
DFX is amazing and has tons of features, and best of all its free.
I have the pro version though.
If its allowed, PM me if yah want the pro
28 Jun 2013   #2
dwarfer66
I have the pro version great little program.
Search this Thread:
Advanced Search
recording problem after installing dfx audio enhancer
Hi after installing dfx audio enhancer i can not record my voice with internal mic of laptop! I uninstalled dfx but problem exist! I can not restore windows and i just reinstalled windows caus if this problem! And after instakking dfx i get this problem again! I tried a lot of settings ... I'm...
restart problem BSOD glitchy audio win7 ultimate w/ m audio 1010lt sou
m audio 1010lt sound card not sure why..usually when I shut down it restarts automatically..recently i was watching a movie and it restarted out of no where..any help appreciated.... windows ultimate 7 amd 6000 3.0 ghz processor 4 gb ram I did do some searching i do have m audio 1010lt and...
BSOD Help and Support
Taskbar Enhancer ?
I'm looking for a way to hide unused programs in the task bar in Windows7 and put them in a vertical pop-up and only show programs that are minimized.
Customization
CCleaner Enhancer
CCleaner Enhancer is a small tool which adds support for over 270 new programs into the popular program CCleaner. The tool uses the WinApp2.ini system built into CCleaner to easily add new rules and definitions for programs. The rules were sourced mainly from the Piriform Support Forum, with...
Software
Using DFX Audio Enhancer with AIMP 2 audio player
Yes, it's possible. :D AIMP can emulate Winamp plugins. For those who use the Aimp 2 audio player and would also like to use DFX Audio Enhancer (note pro version of DFX is not free), here's how to configure it. First you have to have any version of Winamp installed. Next install DFX,...
Music, Pictures & Video
DFX Sound Enhancer
Hei guys a little help here ;D The DFX Sound Enhancer doesn't work in windows 7? (fxsound.com) I've tried to contact the technical suport but they say that works normal. That i just have to download the right version (32 or 64 bits) and install. Anyone here is using that software? knows...
Software
