Sound is very quiet
The sound is very quiet and can barely be heard and even when I mute the sound I can still hear that very quiet sound. Tried reinstalling drivers but nothing changed, still the same.
Gerulis,
Welcome to the forums. Please fill in your system specs
System Info - See Your System Specs
Have filled in system specs. Sorry for taking so long.
And while you are at it,go to general,highlight speakers,properties,enhancements and check loudness equalization,should boost your volume level
Yes, I did. No matter what I do its always the same and like I said before even with sound muted I can still hear it, just very quiet.
I suppose that you have a simple set of two speakers,are those plugged in the (usually) green input at the backplate of your motherboard?Did you try playing with the connector,a bit in or out?Can you verify that the speaker set is operational?
its not my computer and I'm using headphones which work perfectly fine on my computer. Yes, its plugged in the green input, though have tried all inputs/outputs just in case, but only while plugged in the green input that little sound can be heard.
Tried different set of speakers and still the same.
