Windows 7: sound drivers etc /help
01 Jul 2013   #1
italiangrl
MD 64 bit
please help i muted my sounds thats all i did a cppl weeks a go now iv tried to unmute it wont work iv tried the fix it feature etc etc what can i do this is what it last said which in this case now it sais i have no sound devices . ?? dont ask me what happened i never authorized to remove my sound ?? also does anyone know of any good ways of helping me get more memory or help it as well as high cpu usage >> ??? i use google chrome . i also get a lot of crashes iv tried alot of suggestions nothing works im scared to download and remove things as im worried ill remove something im not suppose to here is what computer last said when i tried to get drivers updated the driver for audio device on high definition audio bus is not installed install the latest driver for the device
apply fix
the driver for keyboard filter is not installed install the latest driver for device tried to apply fix then said any help will be wonderful thank you
02 Jul 2013   #2
Faladu
Windows 7 Ultimate Retail Box (64-bit installed) + Service Pack 1
Sounds like you have major issues, run through this tutorial:
Blue Screen of Death (BSOD) Posting Instructions
Need more specifics on the issues as well, and here is help for filling in your system specs:
System Info - See Your System Specs
Just muting/unmuting sound is one thing, Function key + another (info in the manual), usually on a laptop is all that is needed.
No sound after installing sound drivers?
I installed a driver for my sound card, only to find out that sound just wouldn't play on my laptop. (It says that the sound is playing, it's just that it isn't coming through the speakers.) I know that the drivers are updated, so if you're going to ask if my driver is updated, the answer to that...
Sound card drivers show as working but still no sound
Hi, as stated in the subject, I am unable to hear any sound from my speakers since upgrading to the windows 7 64 bit. I followed the other post that I found on this but I still cannot hear any sound. I have a dell inspiron 531. The hardware ids from the device manager are ...
Sound Drivers
Hi there again, My microphone has recently decided to not work at all, only static goes through on skype and when I use sound recorder the bar telling you how loud you are is full. It sounds like a simple driver reinstall, but I cannot find the drivers anywhere:/ Also is it just a sound...
Drivers
please HELP me to get sound Drivers!!!
I am working on a Asus PC and all that I could get on the motherboard is that it is an Asus Mozart 1-2, can someone please get me sound drivers for this motherboard please this is urgent. Thanks a lot guys.:D
Nvidia sound drivers, realtek drivers, or both?
Hello. I have a MSI NF750-G55 motherboard which came with Nvidia sound drivers. Windows update even provided an update for the nvidia drivers once I connected to the internet. However, I also know that there are Realtek sound drivers. Will my system be more stable if I just install the nvidia...
Drivers
no sound drivers
hi! i am using win7 on my lappi but no sound can be heard from the speakers but comes in headphones . i have a compaq CQ45 lappi with AMD motherboard and altec lansing integrated speakers. i dont have drivers for speakers so a message appears as no audio device found. please tell me where i can...
