Windows 7: Small problem with my headsett mic.
13 Jul 2013   #1
MPN
Windows 7 Home x64
Ok so my problem is that my mic picks up almost every sound from my headphones.
I use Skype allot when i`m playing with friends and they can all hear my in-game sounds and my music playing in the back ground. I've tried to tweak the sound level in Skype, and made sure that Skype dosnt automatically adjust the mic volume. And I`ve been in the windows control panel and adjusted the mic a bit there.
And i had to tune the mic boost up a bit as well or else my voice was to low on Skype. And i think that is the main problem. Is there any other way to turn the sound level on my mic up without booting it?
This is a new headsett (Razer Carcharias). Have never had problems like this with any of my older headsetts
15 Jul 2013   #2
MPN
Windows 7 Home x64
After a little more research i found out that its just how the headset is. Cause its an open headset the sound leaks out easy, and the sensitive mic picks up the sound. So i guess the only option i have is to get a foam cover for the mic and see if that helps anything
A small problem
My 500GB HDD just died on me as I was dealing with a bluey - well I think it's dead as it will not show up in DISKPART or My Computer. So I have a Seagate 1TB spare that I aligned a while ago but it is not showing up in My Computer. The Partition Wizard is telling it has two partitions one the...
Hardware & Devices
Small problem
Have fitted a Seagate Barracuda 500GB ST3500413AS in addition to my Samsung 103j Spinpoint as it from new (6 weeks) has been noisy. Howvere I have put in the Seagate but it isn't showing on my Computer readout as anything - anything I've done wrong? The board is Gigabyte h67A-UD3H-B3 and...
Hardware & Devices
Small login problem
Hi! I have a small problem: I have set up my computer with a password to get my mediaplayer to be able to access it sinceit can't work without a password, THEN i have set up my uTorrent to start with windows. But when using a password it stops at the passwordpromt... And i have configured...
Network & Sharing
Small problem
Hey guys, This problem has been bothering me for a long time. I've uploaded pictures to show.. In the picture I have uploaded here; http://i1208.photobucket.com/albums/cc364/Urban_sOlja/taskbar1.png you'll see that yellow exclamation mark sign by the internet icon. But in this picture;...
Network & Sharing
I have a small problem!
Forgive me if this is in the wrong place, I didn't know where else to post it. My problem is this, some small parts of web pages (no matter which browser I use) don't show up and I get an "error 102" I've searched all over for a fix and nothing has worked so far. So i'm wondering if anyone here can...
Browsers & Mail
small aesthetic problem :)
you know like how you can click on an icon in the taskbar, hold left mousebutton down and pull the menu up with moving the mouse upwards? i think tuneup killed that for me and it doesnt seem to work anymore. but it was so slick :D anyone an idea to restore it? re-enabling all animations in tuneup...
General Discussion
