Windows 7: No sound, Realtek sound inputs assigned randomly
19 Jul 2013   #1
aiizawa
Windows 7 Home Premium 64 bit
The realtek audio managers shows that the front two inputs, front mic and headphones, are always plugged in when there is nothing in them at all. When I plug in my speakers to the back green input for sound it inputs both the green one, front speakers out, and the blue input, line in.
Now I get no sound when I set it to HD audio but I get a little sound when its set to ac97. Also there is a constant static ringing sound going on. When the computer is first turned on the speakers do a very large pop, then start winding up getting loader and loader and pops again. Then it just sits with static. This happened when I turned my computer back on.
I tested the speakers and they work just find on other devices so its not the speakers.
How the heck does this happen and how does one fix this?
Thank you guys.
20 Jul 2013   #2
Vertex
Windows 7 Ultimate 32 Bit, Windows Developer Preview, Linux Mint 9 Gnome 32 Bit
I suggest that you install a new version of the Realtek sound driver:
Latest Realtek HD Audio Driver Version
If that does not resolve it, something might be wrong with your sound adapter.
20 Jul 2013   #3
fireberd
The Realtek in your motherboard is the HD Audio type, thus the HD Audio connector from the front panel should be used. However, there may be a problem with the connector/cabling/front panel in the case. Disconnect the front panel connector, at the motherboard and see if the rear jacks work correctly and the RealTek manager shows correctly. If it works OK, that suggests some type of problem with the case wiring or jacks.
Check the Device manager to see if there is anything extra, such as HD Audio Codec, that is listed in the Sound section of the Device Manager. If your video card has HDMI, you should see an entry for that and the entry for the RealTek. Anything else uninstall in the Device Manager, then restart the PC and see if it changes anything.
21 Jul 2013   #4
aiizawa
Unplugged the front panel wiring and its still doing it. Says the front panel is connector still. Everything is the same. I went into the device manager and disabled the ati high definition audio and left the realtek high definition audio going and disabling both of them didn't stop the static ringing.
Realtek Audio not detecting analog inputs
I have a Gigabyte GA-P55-UD3R that has had no problem for quite a long time using Windows 7 64 bit. Recently after a reboot, the integrated Realtek audio no longer detects any analog connection (tried with mic/speakers/headphones) in any of the jacks. I removed the current drivers using add /...
Custom Sound Scheme: Close Window Sound Plays Instead of Chosen Sound
Cheers all, Problem is as stated in the thread; I downloaded, untar'd and set the theme up today. I know it's specifically the "Close Window" sound since it's unique from the others. I'm referring to the following actions in particular (there may be more things I could do to proc it, but I...
Distortion sound using onboard realtek sound card on windows 7ultimate
Hello,i recently upgrade my system from xp to windows7,i use the same realtek driver and get distortions!I try severall drivers,disable all enhancements/levels on speakers properties with no result(2.1speakers-),i configure them in stereo mode,i reduce the default format to 44100 16bits(cd...
Realtek onboard sound. No sound
I don't know how to title this too well but yeah. I have been using a USB headset for quite some time but I recently purchased some Audio Technica ADH-700's. I've plugged them in and woolah!.. Just kidding.. No sound at all :( I have an Avermedia Live Gamer HD Capture Card and with getting it...
RealTek OnBoard Sound Issue - No Sound
Hello everyone, My audio has seem to quit on me. I updated to the newest drivers for my mobo (biostar A870U3) from their download page and now I get no sound whatsoever from my speakers. I have tried uninstalling all of the sound devices from the device manager and letting windows reinstall...
sound problems with Realtek ALC 882 sound card
I have a HP Media Center PC. the Model number is a1412n I am dual booting xp and windows 7, and in windows 7 I am not getting any sound. When I went to check it out, I realized that the computer was only recognizing the front audio jack. So i plug my speakers into the front jack but it still says...
