Windows 7: narrator no sound - and sound vbs file no sound
21 Jul 2013   #1
Total
Windows 10 Pro - 64 bit
I tried this file on my other win 7 and it works fine , but I have no sound with this file . and narrator has no sound also .. system sounds and mp3 's / movies sound good ... Ideas . thanks
File Type: vbs Time.vbs (129 Bytes, 0 views)
22 Jul 2013   #2
Total
Weird - If I change the output to optical , I can hear the vbs file and narrator . Ideas ?
25 Jul 2013   #3
Total
fixed it - re-installed the drivers .. weird stuff ..
Custom Sound Scheme: Close Window Sound Plays Instead of Chosen Sound
Cheers all, Problem is as stated in the thread; I downloaded, untar'd and set the theme up today. I know it's specifically the "Close Window" sound since it's unique from the others. I'm referring to the following actions in particular (there may be more things I could do to proc it, but I...
Distortion sound using onboard realtek sound card on windows 7ultimate
Hello,i recently upgrade my system from xp to windows7,i use the same realtek driver and get distortions!I try severall drivers,disable all enhancements/levels on speakers properties with no result(2.1speakers-),i configure them in stereo mode,i reduce the default format to 44100 16bits(cd...
Sound Control panel takes 2 minutes to open; HDMI sound inconsistent
Brand new Windows 7 Home Premium (6 bit) computer. When I click on the Sound control panel item, sometimes it takes 1-2 minutes to open. But that's kind of minor (although I'd like to know how to fix it), because sometimes the HDMI sound to my HDTV works fine, and sometimes it doesn't work at all....
Powerpoint is recognizing sound clip as movie, won't play the sound
At a lab I've spent numerous hours on this animation that I'm entering into a national competition. In PowerPoint I had my friend narrate it, and uploaded to drop-box. It was all working perfectly, but now at home when I downloaded it most all of the sound clips are recognized as movies, and won't...
How to Normalize a channle sound from a stereo sound file.
Hi to all seven forum, I have a movie audio and its left channel sound is lower then the right side. so I wanted to Increase left channel sound for equal to right side channel. I used Audacity but its "Normalizer" option didn't really works. see the image, there is clearly shown one channel sound...
Missing Sound Video & Game Controller in Device Manager, no sound
Hi Its bit complicated.:D I have 5 year old Compaq Pressario V3611AU notebook with AMD Atholon X2 TK-55 processor. Was using Windows XP and everything working fine. Recently I upgraded RAM to 2GB & processor was changed to AMD Turion(tm) X2 TL-60 2.00Ghz. I installed windows 7 and everything...
