Windows 7: Playing sound through two audio devices simultaneously
22 Jul 2013   #1
tsampson
Windows 7 Home Premium 64 bit
Hello all.
I have Bluetooth speaker that I have hooked up to my computer and is working properly.
I would like to also use the laptop speakers simultaneously to create a kind of surround sound system.
Is this possible? I have found many threads saying that it isn't.
When I use the audio device settings it just changes between the 2 outputs, it doesn't seem to allow me to use them both at once.
Is there any freeware that allows for this type of configuration?
23 Jul 2013   #2
Sub Styler
If the bluetooth speaker connects via a transmitter connected to the 3.5mm jack then its possible, otherwise its not.
23 Jul 2013   #3
fireberd
None that I know of. The one default audio playback device is a Windows limitation. It can't feed two different sound devices at the same time.
Two Sound Devices.. So Two Audio Streams?
My default audio device is a Creative X-Fi Titanium card... but this desktop PC came with a built-in Realtek HD audio device too. Normally all of my sound comes from speakers plugged into the x-fi card and I never use the Realtek device - which I presume is connected to the other (unused)...
Multiple audio playing devices, playing the same sound at once
Hi I've been stuggling with this for a few hours now and am at the end of my wits.. I've got two audio devices that I would like to link to my PC at once. I've got one plug connected to the back panel, and one to the front. But one always cuts off the other. In my sound devices, the system...
Hardware & Devices
Sound Error: no audio devices are installed - hp pavillion dv6500
hi all, im new to this site. I have problem with my sound. There were no problems before but now whenever i try to put the volume higher an error alert saying no audio devices are installed comes on. i have looked around and tried going to services.msc but it didnt work. I really cannot stand...
Audio devices undetected. Headphones or Speakers give no sound
Hi, I recently went into my computer to install a Corsair H80 Water pump for the GPU. Anyhow, after i connected all the cables and turned on the computer again i did not have any sound. Even though im not an expert with computers, i'm pretty sure all the cables are connected right (but there is...
Windows doesn't detect any audio devices: no sound
Hello, my name is Conan. I have installed Windows 7(Ultimate, 64-bits) in 2009, my previous os was Windows XP(32-bit). Although I am really happy with W7 there's something which is a big turn-off. The sound, that is, it hasn't worked on W7 ever since I installed it. It's not the devices that...
2 MP3 audio streams playing simultaneously
Hi all, I have a few MPG4 AVI files that have multiple audio streams (regular & commentary) and MC7 insists on playing both streams at once. If I play the file in Media Player Classic HC, I can choose which of the audio streams to use via a menu. I tried forcing 7CM to use ffdshow by renaming...
Media Center
