HDMI monitor no speakers-no sound from anywhere when connected?
  1. Posts : 292
    Windows 7 Professional
    I have an external monitor with no speakers I use as a dual display along with my laptop monitor. No sound comes out of my laptop speakers nor when I hook up external speakers to it while I have the external monitor hooked up by the HDMI cable. Is there anything I can do to get this to work?
    Thanks,
    Bill
  2. Posts : 740
    Right click on the volume control and then Properties,
    When you connect the HDMI it becomes the default output device, even though it has no speakers.
    You need to change this back to "Speakers" and set as default.
  3. Posts : 292
    When I right click on the volume control, the options it shows are:
    open volume control
    playback devices
    recording devices
    sounds
    volume control options
    It does not give me a properties option.
  4. Posts : 740
    In which case select, Playback Devices
    And try this
  5. Posts : 292
    Thanks so much. That did the trick.
    Bill
  6. Posts : 1
    Windows 7 Home
    Thanks so much.
    It made it easy as butter. Thanks so much.
