Windows 7: HDMI monitor no speakers-no sound from anywhere when connected?
22 Jul 2013   #1
billberry12
Windows 7 Professional
I have an external monitor with no speakers I use as a dual display along with my laptop monitor. No sound comes out of my laptop speakers nor when I hook up external speakers to it while I have the external monitor hooked up by the HDMI cable. Is there anything I can do to get this to work?
Thanks,
Bill
23 Jul 2013   #2
Sub Styler
Right click on the volume control and then Properties,
When you connect the HDMI it becomes the default output device, even though it has no speakers.
You need to change this back to "Speakers" and set as default.
23 Jul 2013   #3
billberry12
When I right click on the volume control, the options it shows are:
open volume control
playback devices
recording devices
sounds
volume control options
It does not give me a properties option.
23 Jul 2013   #4
Sub Styler
In which case select, Playback Devices
And try this
23 Jul 2013   #5
billberry12
Thanks so much. That did the trick.
Bill
31 Oct 2015   #6
Netti
Windows 7 Home
Thanks so much.
It made it easy as butter. Thanks so much.
No Sound via HDMI on monitor speakers??!!!!?!!
Hello guys, I bought a new monitor from LG and connected it via HDMI to my laptop but the sound does not work on the speakers of my monitor could you help me please???
No sound through speakers.Jack not being detected.HDMI sound only?
So I've got a problem,I changed my case 2 days ago and everything went great,all working as it should be.Up until an hour ago,when the lid got stuck in one of the little clips so after a quick bang it went in.But then I lost my picture on both monitors. So I went to investigate,I ended up...
No audio through monitor speakers via HDMI
I purchased a new monitor and it looks great but I can't get the built-in speakers to function. The monitor has inputs for VGA, DVI, and HDMI and I currently have it connected to my video card via HDMI. The front panel audio jack is functioning and I am able to hear audio if I plug headphones in...
no sound through tv via hdmi, sound plays through laptop speakers (idt
Yesterday I installed a new external hard drive - following the installation - my sound no longer played through my television (video is fine, HDMI connection) and sound now comes ONLY through the laptop speakers. The option for HDMI Audio doesn't appear in the 'sound' menus. I have 'checked'...
No sound to HiFi speakers when HDMI Cable Connected
Hi I have connect my laptop using an HDMI cable to my TV. And from my tv I have connected my two HiFi speakers. When the TV is on an AV channel I have sound coming from the TV and HiFi speakers but when I switch it to the HDMI source channel, sound only comes from the TV and not HiFi speakers....
Monitor Speakers not working when connected via HDMI to laptop
Hi, I've recently purchased a Samsung T23A750 monitor and to my disappointment when I try to watch a movie the built in speakers are not functioning. I have a Sony Vaio Z216GX connected via HDMI to the monitor (HDMI-DVI) port. I can definitely see the video, but no audio is playing from the...
