Windows 7: How do i output sound through the back panel jack and the front jack
28 Jul 2013   #11
AddRAM
Windows 7 Pro x64 Windows 10 Pro x64
Not sure why he would want to do that
28 Jul 2013   #12
fireberd
There are several posts here, from users, that want to have both the headset and speakers working at the same time. I don't know why either, but some want that.
Jack
28 Jul 2013   #13
ICIT2LOL
No further comment from the user. Something we said must have fixed it for them.
Yep I reckon so too mate
28 Jul 2013   #14
Jemjem787
MS Windows 7 Home Premium 64-bit SP1
Jack
Maybe some of us have 2 sets of speakers?
29 Jul 2013   #15
ICIT2LOL
Quote   Quote: Originally Posted by Jemjem787 View Post
Jack
Maybe Jem I run a 7:1 system in 5:1 mode on my main machine and I could in theory run another system from the front panel but to what advantage I don't know
All I know ids I do like high quality audio and that is the bottom line for me and I suspect for firebird who I believe has a great deal of experience in this field .
Front panel headphone jack problems
I've seen similar posts regarding this, however none have helped so I'm starting my own one...hopefully someone can help. I upgraded from Windows XP to Windows 7 64bit. In XP, I used the front panel headphone jack for hooking up to my TV, or headset. Since I've upgraded, this headphone jack...
REALTEK|using front speakers through rear output jack - possible?
hi Every time I wanna use speakers instead headphones,I have to use the same headphones output (green one - back panel), and therefor to disconnect and connect cables.. not very comfortable I've tried to use the black output, and it worked, but only as a 'rear speakers', both left and right...
No sound in front panel jack
Hi, I recently upgraded from WXP to Win7 and ever since, I was not able to get any audio coming through my headphone which is plugged to the speaker port on the front panel of the PC. Speakers connected to the rear port works fine though. Can someone help?
No sound - Windows only showing front jack and not rear jack
Hi everyone, I recently reinstalled Windows 7 pro on my PC. Sound was working fine before. Now Windows only shows a front jack in the sound playback device settings. There is no front jack, however, only a rear jack and it is not working. If I play music the levels monitor shows sound playing,...
No sound in Front Panel Jack
I had this problem since i installed Windows 7 yesterday and my speakers in the back of my computer work fine, but just i cant put my headphones in the front panel. I saw several topics on here about it, but i read them and couldn't find a solution. I tried other audio codecs, i tried to Install...
can't set front jack as default audio output (notebook)
Hi !'ve got a probelm with my compaq 615 i had a problem with my audio quitting on me after the laptop went to sleep (which required a reboot) so i reinstalled the drivers (IDT HD) now my laptop speakers are set as the default audio device and my headphone jack is set as the default...
