Windows 7: How do i output sound through the back panel jack and the front jack
26 Jul 2013   #1
Jemjem787
MS Windows 7 Home Premium 64-bit SP1
Hey guys! I want to output sound both through the headphone jack on the front of my case and the sound jack at the back of the computer, how would i do this? I looked around in the sound setttings and the realtek audo and couldn't find anything.
26 Jul 2013   #2
fireberd
Some RealTek HD Audio Managers have an option to either mute the speakers when a headset is plugged in or like what you want, do not mute the speakers.
On mine, click on Device Advanced Settings and it brings up another screen with the options.
How do i output sound through the back panel jack and the front jack-capture.jpg
26 Jul 2013   #3
ICIT2LOL
Mate I have the -V board and I have a cable hook up from the board header to it yours should have the same. Did you miss the cabling when you built??
If you look you can find the headers along the side of the board which the 6Gbs SATA ports are on
http://www.asus.com/Motherboards/P8Z77V_LX/#overview
26 Jul 2013   #4
Jemjem787
Quote   Quote: Originally Posted by ICit2lol View Post
P8Z77-V LX - Motherboards - ASUS
What do you mean by headers?
27 Jul 2013   #5
ICIT2LOL
Take a look at the pics self explanatory and this is the reference for the manual
A coupl of extra shots to make it clearer
How do i output sound through the back panel jack and the front jack-asus1.png   How do i output sound through the back panel jack and the front jack-manual.png   How do i output sound through the back panel jack and the front jack-man3.png
How do i output sound through the back panel jack and the front jack-man2.png
27 Jul 2013   #6
fireberd
Did I miss something? I thought the user wanted to output from the headphone and speakers at the same time? Not how to hook up the front panel headphone/mic jacks?
27 Jul 2013   #7
ICIT2LOL
Jack in post #1 Jem says he wanted the headphones from the front jack and from the back or at least that is how I read it
Like you said mostly the phones in either source will disable the speakers but I think maybe Jem is under the impression - I stand to be corrected that he can have headphones connected to both at the same time for a second listener?? I suppose I should have asked if he had those headers hooked up to the front panel
Sorry mate I will butt out.
27 Jul 2013   #8
fireberd
Its OK, just that I thought I had misinterpreted what the user wanted.
In some RealTek systems, such as mine that I posted the screen capture, there is an option to have both the headphone and speakers active at the same time, or as it usually works the headphone mutes the speakers.
Jack
27 Jul 2013   #9
ICIT2LOL
Jack
No worries mate the post could have been a tad more expicit
28 Jul 2013   #10
fireberd
No further comment from the user. Something we said must have fixed it for them.
Front panel headphone jack problems
I've seen similar posts regarding this, however none have helped so I'm starting my own one...hopefully someone can help. I upgraded from Windows XP to Windows 7 64bit. In XP, I used the front panel headphone jack for hooking up to my TV, or headset. Since I've upgraded, this headphone jack...
REALTEK|using front speakers through rear output jack - possible?
hi Every time I wanna use speakers instead headphones,I have to use the same headphones output (green one - back panel), and therefor to disconnect and connect cables.. not very comfortable I've tried to use the black output, and it worked, but only as a 'rear speakers', both left and right...
No sound in front panel jack
Hi, I recently upgraded from WXP to Win7 and ever since, I was not able to get any audio coming through my headphone which is plugged to the speaker port on the front panel of the PC. Speakers connected to the rear port works fine though. Can someone help?
No sound - Windows only showing front jack and not rear jack
Hi everyone, I recently reinstalled Windows 7 pro on my PC. Sound was working fine before. Now Windows only shows a front jack in the sound playback device settings. There is no front jack, however, only a rear jack and it is not working. If I play music the levels monitor shows sound playing,...
No sound in Front Panel Jack
I had this problem since i installed Windows 7 yesterday and my speakers in the back of my computer work fine, but just i cant put my headphones in the front panel. I saw several topics on here about it, but i read them and couldn't find a solution. I tried other audio codecs, i tried to Install...
can't set front jack as default audio output (notebook)
Hi !'ve got a probelm with my compaq 615 i had a problem with my audio quitting on me after the laptop went to sleep (which required a reboot) so i reinstalled the drivers (IDT HD) now my laptop speakers are set as the default audio device and my headphone jack is set as the default...
