Windows 7: No Level Indicator When Using Keyboard Audio Volume Controls
02 Aug 2013   #11
guitarfiend
windows 7 home premium 64 64 bit
Wow !! Thanks everybody for all of your suggestions.I just kind of glanced over them at this point (there were so many). I'll let you all know "what becomes of the baby" once I have time...I WILL say-I HAVE "looked at" the "control point" thing and even downloaded it. After I screwed around with control point for about two hours I gave up & decided to just live with there being no solution for this problem.But,you all have given me more ideas.I gave up on control point because after I downloaded it,it seemed to be a REALLY huge file for just that one function AND I really couldn't quite even figure out how to even turn the damned thing on !!??
02 Aug 2013   #12
maxie
windows 7 home 64bit
Hi there If you have downloaded the Dell Feature Enhancement Pack.. Use the FN key + Arrow keys to turn the Volume up or down
02 Aug 2013   #13
guitarfiend
Maxie...that is not the problem ! The problem is that when the function keys (volume up/down/mute) on the keyboard are used for audio levels there is no on screen display for the levels.AND-I haven't tried the Dell Feature Enhancement Pack yet.
02 Aug 2013   #14
maxie
Fair enough a bit surprised though the Function keys work with out the pack
02 Aug 2013   #15
AddRAM
Windows 7 Pro x64 Windows 10 Pro x64
Just click on the sound icon in the taskbar.
My new Logitech G510 keyboard has a volume control on it, it`s awesome
03 Aug 2013   #16
SandeepP
Winndows 7 32 bit
Quote   Quote: Originally Posted by guitarfiend View Post
Hi guitarfiend,
I would like to inform you that control point is complete package software with various different functions also including the volume controls.
As it has not shown you the notifications that you are looking for then I would request to kindly install the enhancement pack shared in the earlier post.
Please check with the enhancement pack installed and let us know the results so we can advise you further if required.
keyboard volume controls wont work
after clean install my microsoft curve 2000 keyboard volume -/+ /mute wont work ive installed the intellitype software and reinstalled realtek hd sound drivers and there is nothing it worked previously b4 clean install
Hardware & Devices
No volume level indicator on my gateway NV77H
Okay so I just did a clean install to fix some various issues with my machine, it has fixed all but one, I cannot see the volume levels ( or any other notifications for that matter caps lock etc, but that's the topic for another thread) when hitting the keyboard buttons on the laptop. I have...
Need help with Epson printer ink level indicator not working.
I'm not sure is this is the correct place to post so please move it elsewhere if necessary. I've had this issue for awhile but recently got burnt with a bad print because cyan was low on my Epson Artisan 710 printer. I've attached a capture of the properties window that shows printer ink level...
Software
Volume controls on K800 Keyboard do not work with Headphones
Morning, Bit of a weird one here...within the last week - I installed a fresh copy of Win 7 x64 SP1 on a new office workstation. I am using the Logitech K800 keyboard and J.River Media Center for media playback. NOTE: I am using the Gigabyte EP45-UD3R motherboard and it's onboard Realtek...
Volume Mixer Audio Output Indicator Gone
You know when you are playing an audio file and you are able to see the current output volume of the song in the Windows7 Volume Mixer as a semi transparent bar behind the volume slider? For some reason, mine is gone. Also when I put headphones in my PC it is really loud and I have to keep my...
Battery Level Indicator for Netbook
I have just obtained an Asus Eee 1015PED Netbook and the battery indicator doesn't appear to be very accurate. Can anyone recommend a reliable replacement. I have googled but would appreciate some recommendations from a user. Thanks.
Performance & Maintenance
