Internal microphones not working
  1. Posts : 5
    windows 7 professional 32 bit
    I am using a Dell Latitude E5520 laptop but the laptop doesn't recognise that it has internal microphones!!
    I've googled the problem and have downloaded drivers from Rwealtek etc but to no avail.
    I've included a screenshot of the recording devices tab which only shows unplugged microphones.
    I'd welcome any advice please
    Cheers
  2. Posts : 1,009
    Windows 7 Ultimate 64 bit SP1
    Hi and welcome to Seven Forums!
    I know you have said that you have tried it, now please give it one more chance and if it fails to work we will dig deeper to try to solve the problem.
    Realtek
    After accpeting the terms you need to download the first driver from any of the 3 servers on the right.
  3. Posts : 5
    Is this the one?
    Chris
    Attached Thumbnails Attached Thumbnails Internal microphones not working-realtek.png
  4. Posts : 1,009
    Yes, go ahead and click on the US1 on the right in the very first row (starting with 32bit...)
  5. Posts : 5
    Cheers, got about another 15 mins for it to finish downloading
    Chris
  6. Posts : 5
    I've now re-started the laptop, what's the next step?
    Chris
  7. Posts : 5
    I've re-loaded the Realtek audio drivers and nothing has changed I'm afraid, might have to accept that the built in microphones aren't going to work after all.
  8. Posts : 1
    issy1, just reinstall the audio driver and it might work. I've experienced the same problem and after I've installed the latest audio driver from DELL website, it worked.
  9. Posts : 2
    windows 7 profesional
    microsoft has a fix it file for win 7 audio and sound recorder you might try that and my external mic wouldnt recorde anything either I found voice recognition in control panel and turned it on and wala my mic now works on sound recorder and my roxio narator
  10. Posts : 1
    Windows 7 32
    Drivers are here
    I can confirm the DELL Latitude E5520 has well integrated microphone.
    Just got the same problem with Skype and used the drivers available for download from DELL website:
    Google the name of the driver and you should easily get it.
    IDT_92HDXXX-HD-AUDIO_A03_R297613.exe
    INstall software.
    Then go to your peripheral manager.
    Click on the audio controler and choose the "update drivers", then point to the directory created by the executable.
    C:\dell\drivers
    Hope it helps.
    Chris.
