Windows 7: No Level Indicator When Using Keyboard Audio Volume Controls
28 Jul 2013   #1
guitarfiend
windows 7 home premium 64 64 bit
Guess what guys ? I have a new problem ! Imagine that.I've googled for answers and closest I came was the Dell quickset app.But,after downloading 3 versions (the last one actually installed) my problem is not solved.It's a small issue really.But,annoying....
The problem is when I use the keyboard buttons to either raise/lower/mute audio volume levels,the buttons work BUT...no level indicator is being displayed onscreen.Anybody else ever have this problem and how did you solve it ?
This is mommas laptop and any help much appreciated.The laptop is a Dell Latitude E6400.I'll be back in about 30-45 mins.Gotta run to the grocery store for her.
28 Jul 2013   #2
Anak
Win 7 Home Premium 64bit Ver 6.1.7600 Build 7601 - SP1
Have you tried this?
Quote:
Look on the taskbar and see if you have the Dell Quickset icon there. It's in the shape of a blue Q with a yellow tail sticking out of it. Click the icon (on some versions you must right click it) and uncheck 'disable onscreen volume meter.'
If the icon is missing look under Start/All Programs and see if you have the Dell Quickset program. Follow the arrow to the word 'Quickset' and click on it and the 'Q' icon should appear on the taskbar.
Source: Volume control not showing up on screen? Dell Inspirion 1545 - Laptop Audio Forum - Laptop - Dell Community
Disregard model, quickset is the same for all models.
If the Q icon keeps disappearing check "notifications" Control Panel\All Control Panel Items\Notification Area Icons to force it to remain visible.
Notification Area Icons - Hide or Show System Icons and Notifications
28 Jul 2013   #3
guitarfiend
Anak...no dice.It appears to me that there is no Dell Quickset even installed.Or,I can't find it.In fact,when I went to Dells site,it almost appears that Quickset was never even meant for this model !? I even went into ctrl pnl & looked around for something that I might be able to change & ??? Hmmmmmmm.Anymore suggestions ?
No Quickset icon on taskbar or start menu.I'll be here poking around for maybe another hour for answers if you happen to find anything.Thank you Anak.
29 Jul 2013   #4
Anak
Would your Mom's E6400 (E64) be running Vista 32 bit?
Quote   Quote: Originally Posted by guitarfiend View Post
Try looking for the file name R163012.exe in C:\Program Files (x86)\Dell or C:\Program Files\Dell, if this is the x64 version. You might also try copy/paste R163012.exe into the Start/search box and see what comes up:
Attachment 278655
Oh, it was available for the E64 but I'm seeing reviews that it was manufactured in, around, the Summer/Fall of '08?
When a model gets to be older than say 3years, Dell has this habit of "cleaning up" their website sending a user to pages that say:
  • "Invalid or demoted driver"
  • "This product is unavailable. Below we have suggested a comparable system".
IMHO. This has a twofold affect,
  1. It's good for Dell's bottom line especially if you're a die-hard Dell user, If I can't find support for my machine I might as well buy a new one.
  2. But, it makes it harder for a Dell user that likes the way their machine works (Your Mom). If I can't find support for my perfectly good machine I'm just going to try harder to find help for it like your doing right now.
Well, its a good chance that if you can't find the file, you won't find the program or icon.
Suggestions? To paraphrase John Paul Jones; I haven't yet begun to suggest!
Getting back to Quickset, Do you know how to enter the BIOS on the E64? Check its version, look for; A03, A05, A09, it may be in the title line or it may be in system information I'm not sure. If its different than those three post back the version.
If you can't find a match try each one of these three, one at a time, right click the file and click "Run as Administrator" Step #8 in the following tutorial. If it doesn't work try installing it in Compatibility Mode for Vista.
Dell QuickSet, v.8.0.11, A03
Dell QuickSet, v.8.2.14, A05
Dell QuickSet, v.8.2.20, A09
More help for the E64:
Windows Vista Tutorials
https://www.dell.com/support/Manuals...latitude-e6400
Your problem may be deeper, there is a member that works for dell if I can track him down I'll ask if he can stop by for a look.
30 Jul 2013   #5
SandeepP
Winndows 7 32 bit
Hi guitarfiend,
Latitude system doesn't get system with the Quickset software. We have a DELL control point software for these systems which provides better ease of functionality on the system.
You can download the same from the below link:
http://downloads.dell.com/FOLDER4375...IN_R279622.EXE
Also, you can download all drivers and applications for your system at the below link:
Drivers for Latitude E6400
Please check the same and let us know the results so we can advise you further if required.
30 Jul 2013   #6
Anak
SandeepP, Thank you for stopping by and offering your assistance.
Do you know if the control point software offers the on screen volume level indicator?
30 Jul 2013   #7
maxie
windows 7 home 64bit
Hi there .. Its the Dell Feature Enhancement Pack 2.2.1 that is needed
31 Jul 2013   #8
SandeepP
Winndows 7 32 bit
Quote   Quote: Originally Posted by Anak View Post
Hi Anak,
Unfortunately I don't have the access to a Latitude system currently to test the application for its complete features.
However, Latitudes doesn't come with the Quickset software. Instead it comes with Control Point which provides various features to control various function of the system at one click.
As suggested by maxie user can also download the Enhancement Pack at the below link and let us know the results:
32 bit
64 bit
Hopefully one of the software should be able to resolve the issue of the OP.
31 Jul 2013   #9
Anak
Okay, it's up to the original poster (OP) now. we'll just have to wait until he gets the chance to try Maxie and your suggestions.
01 Aug 2013   #10
SandeepP
Winndows 7 32 bit
Hi Anak,
Yes, hopefully one of the software should resolve the issue user posted.
keyboard volume controls wont work
after clean install my microsoft curve 2000 keyboard volume -/+ /mute wont work ive installed the intellitype software and reinstalled realtek hd sound drivers and there is nothing it worked previously b4 clean install
Hardware & Devices
No volume level indicator on my gateway NV77H
Okay so I just did a clean install to fix some various issues with my machine, it has fixed all but one, I cannot see the volume levels ( or any other notifications for that matter caps lock etc, but that's the topic for another thread) when hitting the keyboard buttons on the laptop. I have...
Need help with Epson printer ink level indicator not working.
I'm not sure is this is the correct place to post so please move it elsewhere if necessary. I've had this issue for awhile but recently got burnt with a bad print because cyan was low on my Epson Artisan 710 printer. I've attached a capture of the properties window that shows printer ink level...
Software
Volume controls on K800 Keyboard do not work with Headphones
Morning, Bit of a weird one here...within the last week - I installed a fresh copy of Win 7 x64 SP1 on a new office workstation. I am using the Logitech K800 keyboard and J.River Media Center for media playback. NOTE: I am using the Gigabyte EP45-UD3R motherboard and it's onboard Realtek...
Volume Mixer Audio Output Indicator Gone
You know when you are playing an audio file and you are able to see the current output volume of the song in the Windows7 Volume Mixer as a semi transparent bar behind the volume slider? For some reason, mine is gone. Also when I put headphones in my PC it is really loud and I have to keep my...
Battery Level Indicator for Netbook
I have just obtained an Asus Eee 1015PED Netbook and the battery indicator doesn't appear to be very accurate. Can anyone recommend a reliable replacement. I have googled but would appreciate some recommendations from a user. Thanks.
Performance & Maintenance
