WASAPI not working does it need soundcard capable
  1. Posts : 143
    Windows 7 Ultimate x64 build 7600
    Using JRMC I cant get sound when I switch to WASAPI, only direct sound & wave output works.
    If I switch to ASIO or WSAPI there is no sound & the program hangs.
    I have a creative audigy value sound card is it not capable of WASAPI or does it not work on windows7 x64 version yet?
  2. Posts : 686
    Windows 7 x64 Ultimate SP1
    If you are using WASAPI, the output from your media player has to match the capabilities of the card, otherwise all you'll get is silence.
    So, if it is 24-bit sound capable, you have to send 24-bit output to it.
  3. Posts : 143
    Strange things happening, Its indeed a 24 bit card & I cant play the sound using 24bit, but when I change the Speaker properties to 16 bit,48000 DVD quality & in JRMC it still remains 24bit as output the sound plays fine using the WASAPI.
    Bit confused whats happening what I am doing wrong?
    Attached Thumbnails Attached Thumbnails WASAPI not working does it need soundcard capable-2009-10-19_200938.jpg
  4. Posts : 686
    Too many channels? Buffer length (should be 2000 ms methinks..)?
    Dunno, I test WASAPI with foobar, and it plays 24 bit - but I think that it sends 44100 Hz sound..
  5. Posts : 143
    Found some good reading in these threads, hope its useful for others who might need the same info.
    WASAPI output in Vista and above
    Question about WASAPI and other audio output modes
  6. Posts : 143
    I have 4.0 speakers & tahts what I have chosen in options
    I have set 3 sec buffer length
    I now see many sub options related to WASAPI so I guess I need to experiment with them.
