Windows 7: Monitor when recording on the Sound Recorder
31 Jul 2013   #1
GeorgeLawshe
Is it possible to monitor what I am recording when I am using the Sound Recorder
31 Jul 2013   #2
fireberd
What are you going to record? Mic input? or some other input.
I'm not sure about the Sound Recorder, as I don't use it. The free, and popular, Audacity recording program will allow you to monitor what you are recording, whether its from the Mic, Line In or streaming audio from the Internet (if you have Stereo Mix).
Audacity: Free Audio Editor and Recorder
Sound Recorder: Seems to be recording, but playback via WMP is silent
I've never used Sound Recorder before. I want to use it to record a flute choir I play in, not something coming in from the computer. When I try to record something, the green bar seems to indicate that it's detecting the sound. I save the wma file. When I play it with WMP, there is...
Sound Recorder Not Finding Existing Recording Devices
Hi, I canít get my sound recorder reliably working. Each time there is a hassle to get it back running and sometimes it never finds a recording device although my laptop has a soundcard with stereo mix and an internal mic. I had both already working, recording from Stereo Mix and recording from...
livestream recording in sound recorder
hi to all and everyone i'm currently trying to find a way to add the stereo mixer into my recording panel. i've got all my otions showing which includes all disabled/disconnected option on my recording panel. i'm actually trying to record some live music in paltalk. the only way it's been...
[Recording] Stereo Mix Available, Sound Recording Not
Hello. I am EpicallyAWSM. Alright before I explain, I must tell you that I WAS able to record audio previously. I'm having a problem while recording audio with Fraps (a game video-recording software). Previously, I was unable to find the Stereo Mix at all, until I found the Drivers CD that...
Help! Recording audio with my sound recorder
Hi, I have a samsung n150 netbook. I've been trying to record from the internet using my sound recorder. I have stereo mix showing and enabled in my audio setting (in recording) but i can't record any sound!!! It worked once but I cant seem to get it to work again.... Please help.
How to record a crisp clear recording using windows sound recorder?
Hello, i have a question regarding the windows sound recorder. I'm trying to record an audio clip from a utube video and when i record it's not clear and i can hear my hone background noise, i'm assuming that the mic is enabled... how do i mute that? i just want a crystal clear recording =) feed...
