Windows 7: Need Help Converting Mic line in to Audio out (Is it even possible?)
31 Jul 2013   #1
rodgersa1982
windows 7 64
My normal headphone input is not working properly since i broke a pair of headphones inside the connection jack . I managed to get the broken piece out, but now its not working correctly and has a short in it. I can only hear out of one side unless I hold the jack in a certain position ... well as you can imagine this would be very annoying trying to do while watching a movie or listening to music. I cant afford to have it fixed so I am trying to learn if I can use my mic input for my headphones as an audio out ? I have attached dxdiagnotics. file to this thread.
The specs on my pc are as follows :
HP G60 Notebook PC(laptop).. Windows 7 home premium 64 bit (6.1 build 760L)
Pentium (R) Dual Core CPU T4300@2.1GHZ(2CPU's),4096MB(RAM)DirectX11.
Mobile Intel(R) 4 Series Express Chipset Family
Sound:Conexant Pebble High Definition/Intel(R) High Definition Audio HDMI
Thanks in advance for your help !
31 Jul 2013   #2
fireberd
I've only seen that possible on one PC. Of all the others, I've seen or worked on, the mic jack could not be remapped to be an output.
As an alternative, you could use a cheap USB connected "sound card" and use that instead of the built in sound.
Here is a cheap one I found doing a search. I have no info on it, just what I found doing the search. But for $5.75, its cheap enough. External 7 1 Channel USB Sound Card Audio for Laptop PC Computer Adapter Device | eBay
31 Jul 2013   #3
rodgersa1982
windows 7 64
If thats the best I can hope for I guess thats helpful enough..Thanks
USB generic audio driver Line level input
How do you force the generic USB audio driver in Windows 7 to operate at LINE level instead of microphone level? My Audio Technica Turntable uses the generic driver and I have to run the microphone level all the way down to 4 (out of 100) in order to get the proper level. The old XP driver had a...
cmd line way to mute line in realtek hd audio card
I have a line of music audio entering my realtek card to accompany a powerpoint slideshow, together they go out on our community cable channel. I need to kill the input, the music audio that is directly plugged into the card in the back of the pc, so that when I schedule a video (bod meeting...
Realtek Audio Manager Line In (Apple Headphones)
Hi, I recently purchased a new desktop for myself, and upon trying to plugin my apple headphones to watch netflix, I found that I was having some trouble. When I plugin my apple head phones, I get a popup that looks like this: ...
How do i use the line level audio input port?
Hello, i was wondering how can i use the blue input port on my pc for my speakers? I've run out of ports to put my speakers as my headphones are taking up a slot. I've tried plugging it in and changing the speaker configuration and it plays sound but not all the sound, for example it's missing the...
System shutdown while converting audio
My computer turned itself off, but not normally. It was an abrupt shutdown, as if the power was cut. I was downloading files, converting audio m4a - mp3 from my C drive to D drive, surfing, and listening to music. The processor was at 100% on all cores. Tj Max is 70*c the temps were at 73....
General Discussion
How to set blue audio port as line-out?
Hi all, first of, sorry if I post this in this section and on the other, I'm not sure where to post specifically. So, I'm having this problem since I switched to Windows 7, there are 3 rear audio ports, and these are; Blue, Green and Pink. The Pink is for the mic-in, green for...
