Does setting the "subwoofer" to 100 actually produce any improvements?
  1. Posts : 13
    Windows 7 Professional
    Hello
    I would like to know if there is any improvement to sound quality if I go to
    Speaker properties>levels>subwoofer and set it to 100
    since the default is disabled and my one other question is it safe to set it at 100 as I require to listen to great quality songs and a bit concerned if this can cause any damage to the laptop speakers/headphones
    Any internal setting should not damage the speakers.
    You failed to include the actual Dell laptop model (an example Inspiron 1501) so I can't research what your PC actually has.
  3. Posts : 13,576
    A laptop does not have a sub woofer, so why are you bothering ?
    A sub woofer is an external component of an hd theater, an the volume for it is controlled by the receiver or by the sub-woofers own volume control.
  4. Posts : 2,973
    Unless you have some 2.1 or better system, changing that setting will more than likely not do anything.
  5. Posts : 13
    well my laptop has a built in subwoofer and i think it also has 5.1 surround. My laptop is xps 15 and it has a audio software max waves audio but i was thinking if i set the windows subwoofer would it make a bit of difference
  6. Posts : 13,576
    Really ? What size is the sub woofer ?
    I see nothing in this review about a built in sub woofer.
    http://www.cnet.com/laptops/dell-xps...-35338249.html
    I`ve never seen or heard of a laptop with more then 2 speakers.
  7. Posts : 2,973
    I've heard of a laptop with a tiny subwoofer in the bottom. I think maybe whatever Surround/5.1 sound you have is probably simulated.
  8. Posts : 13
    yeah there is a small built in subwoofer under the laptop and the model is: l502x
  9. Posts : 13,576
    A laptop with a built-in sub woofer, Amazing
    A 5.1 system requires 5 speakers and a sub woofer.
    Does your laptop have 5 speakers too ?
  10. Posts : 13
    sorry i meant the system supports 5.1 and i could purchase external speakers to make it up 5.1. Im currently still thinking if it would make any changes by adjusting subwoofer to 100
