Windows 7: Making Subwoofer Sound Louder
05 Aug 2013   #11
GARoss
Windows 7 64-bit
jacobpetrov,
With more info about your PC's hardware I could be more specific, but we'll wing it for now.
  • Check my attachment for connections. Make sure you have all three connections exactly as in the diagram. This is critical. NOTE: Each audio connection is numbered. (I added color to the original B&W illustration.)
  • There is a Bass Level control on the back of the subwoofer. Set that relatively high for now.
  • 20% volume level on the other speakers is a good starting point.
If the above doesn't help we need more info.
  • Is this a new product or one that has stopped working properly?
  • Did you build this PC?
  • Is audio built into the motherboard or separate audio card?
HTH
05 Aug 2013   #12
jacobpetrov
Windows 7 Proffesional 64 bit
i checked all the connections and they are same like the diagram ,
i checked the bass level control on the back of the subwoofer and its on its full power (stongest bass possible)
it is a new product , bought it from a store , i DID NOT build this computer , a computer shop built it for me for gaming and such about 4 years ago ,
im not sure if the audio is built in the mother board or a sound card ... i have a screen capture of the device manager > sound :
Screenshot by Lightshot
is there a way to check it ?
05 Aug 2013   #13
linnemeyerhere
Windows 7 Ultimate 64
Can you pull out your receipt or open it up and get some detailed pictures of the individual components. Can you give us a screen shot after right clicking on the speaker icon in lower right corner and left clicking playback devices.
General rule of thumb if the audio has two rows of plugs then that's an on board audio and if it's just one longer row then that's a sound card as pictured above.
05 Aug 2013   #14
NoN
With the onboard audio you might have to see the unchecked box "Equalization Loudness" in Sound Options to boost the overall system sound.
If you have a PCI or PCI-e card install you should have to software from the brand installed and therefore could set your own sound options.
Check whenever you have an onboard or PCI Card installed!
05 Aug 2013   #15
jacobpetrov
NoN , i dont have any softwares from the brand so i guess its onboard ? and the Equalization Loudness is not checked in there ... should i check it ?
05 Aug 2013   #16
NoN
Quote   Quote: Originally Posted by jacobpetrov View Post
You could give it a try...some reporting that when checked on some player like iTunes it does lower the sound (kind of muffling it)... but that in general with other players it had boost a gain to their sound system.
If you have dolby settings in WMP, set it normal. Check also if in WMP the SRS WOW doesn't muffle the sound when "Equalization Loudness" in On.
Just test with a media file and see if it does improve for you. On my side before i went to an internal PCI Card, the box was checked on my onboard and playing with WMP12 it was fine.
05 Aug 2013   #17
GARoss
Windows 7 64-bit
I'm wondering if your subwoofer might be defective. Can't think of where else the problem might be. Sorry.
sound card louder?
Hi, will a sound card , a pretty good one $50. (creative or asus, etc) make your computer (speakers) louder? thanks
Surround 5.1 problem, Only subwoofer produces sound
Hi everybody. Well i have a stereo 5.1 system by Creative, version SBS 580. When i first got the computer everything was fine, then my brother bought those headphones, so we didnt use the speakers at all. so after about 1-2 years without use i plugged them in and tried to use them. The...
Subwoofer very low sound
Hi everyone Recently i upgraded my GC to Sapphire 5750 as well as my HDD, so I do a clean windows 7 installation. The problem with my sound is, i need to turn the bass volume high (almost max) to actually hear very low bass sound from it. I never had this problem before upgrading Im using...
Creative Sound Blaster Live 24 Bit - No Subwoofer
Hi Guys! I hope I'll get an useful answer here! My problem is that i don't get any bass out of my subwoofer, my system (as i configurate) recognizes my subwoofer, but as soon as i listen to music there's no sound coming out of it! My other speakers work, but only the bass is missing! I...
No subwoofer with 5.1 sound.
Hey, So i have on-board realtek HD audio card (6 jack) with my 5.1 system connected via 3 jacks (front , surround & sub). The problem is that i've just run the auto calibration thing with the microphone and it worked fine and calibrated all of my speakers, but now my subwoofer doesnt work with...
No Sound from speakers only from reflex subwoofer
Hi, I just upgraded my HP dv7-1135ea from Vista to Windows 7 RC and the speakers are not producing sound, only the reflex subwoofer at the base of the laptop is producing sound. Is there something I can do to get the speakers working? While installing Windows 7, the installation complained of...
