Windows 7: Making Subwoofer Sound Louder
03 Aug 2013   #1
jacobpetrov
Windows 7 Proffesional 64 bit
hey , i have a 5.1 speaker system by creative and i have a question ;
is there any program that can make my normal speakers sound quiter but to leave my subwoofer the same loudness ... i might not be very clear and i cannot express myself very good but i have an example : in the sound section in control panel you can make the right speaker louder or left (and such) and there is also an option for subwoofer but it wont make it louder... so basicly my question is can i make my subwoofer sound louder compared to the other speakers ?
03 Aug 2013   #2
chaosrealm93
Windows 7 Pro 64 bit
you could try messing with the EQ in your media player. boost the bass frequencies (125Hz and lower). i recommend against this though, you are changing what the music is supposed to sound like.
04 Aug 2013   #3
jacobpetrov
can you tell me how to do it ? i couldnt really see those options...
thanks
04 Aug 2013   #4
fireberd
You can try with EQ (tone controls) but any real bass boost would be in the speaker system. You may have to change to a different speaker system to get what you want.
04 Aug 2013   #5
GARoss
Windows 7 64-bit
Quote   Quote: Originally Posted by jacobpetrov View Post
An easy way is to turn your main speaker levels down & your overall volume up. Creative 5.1 have the necessary controls to do this.
04 Aug 2013   #6
chaosrealm93
i dont think windows media player 11 has enhancements by default, but you can go download them. if you use itunes (like me), prett ctrl+shift+2 to view the EQ. again, i highly recommend AGAINST this, you are changing what the music is intended to sound like
04 Aug 2013   #7
jacobpetrov
hey GARoss , in the sound options i set all the speakers to 20 but the subwoofer but even when i put it on high volume its still the same bass as before...
fireberd, what do you mean when you say ''You can try with EQ (tone controls)'' ? is it a program or what ?
chaosrealm93 , i do not use Itunes and pressing ctrl+shift+2 does nothing... and i just want a little more bass in some songs thats all....
04 Aug 2013   #8
fireberd
If your sound has a EQ controls you can set the low frequencies up higher and that will help to amplify the bass more, but if the speaker system isn't capable of louder bass it won't do any good. I don't think you can make it thump like high powered car systems, which it sounds like what you want to do.
I have a recording studio and deal with audio, EQing, etc daily.
04 Aug 2013   #9
GARoss
Windows 7 64-bit
Hey jacobpetrov,
I'm also assuming we're talking about the same thing but maybe not. If you mean the bass response isn't very deep or robust you have a different problem than what I was referring to. I'm assuming you'd like to bring up the bass level.
It would be helpful to have the model number of your Creative Lab 5.1 speakers. I use to have a CL 5.1 system for my PC. Maybe the controllers have changed but the principal hasn't. You should be able control your speakers several ways & I'm not referring to iTunes, WM Player or whatever; just your CL 5.1 controls. There should be a master system volume control as well as independent level controls for the other 5 speakers & maybe a control for the sub. These are the volume or level controls I'm referring to. I'm sure you installed Creative Lab's software which should have level controls as well but these are usually for system setup. The level controls could be sliders, too.
So, when you say you have it set at 20 I have no idea if 20 is in the middle, on the low side or at max volume. Once again, it would be helpful to have the model number of your CL 5.1 speakers. Get back to us soon!
04 Aug 2013   #10
jacobpetrov
hey GARoss , my speakers model is creative sbs a520 5.1 , and when i say 20 it means that the max is 100 and i put all the speakers on 20 percent out of 100 and the subwoofer stays at 100
thank you very much for answering
Search this Thread:
Advanced Search
sound card louder?
Hi, will a sound card , a pretty good one $50. (creative or asus, etc) make your computer (speakers) louder? thanks
Surround 5.1 problem, Only subwoofer produces sound
Hi everybody. Well i have a stereo 5.1 system by Creative, version SBS 580. When i first got the computer everything was fine, then my brother bought those headphones, so we didnt use the speakers at all. so after about 1-2 years without use i plugged them in and tried to use them. The...
Subwoofer very low sound
Hi everyone Recently i upgraded my GC to Sapphire 5750 as well as my HDD, so I do a clean windows 7 installation. The problem with my sound is, i need to turn the bass volume high (almost max) to actually hear very low bass sound from it. I never had this problem before upgrading Im using...
Creative Sound Blaster Live 24 Bit - No Subwoofer
Hi Guys! I hope I'll get an useful answer here! My problem is that i don't get any bass out of my subwoofer, my system (as i configurate) recognizes my subwoofer, but as soon as i listen to music there's no sound coming out of it! My other speakers work, but only the bass is missing! I...
No subwoofer with 5.1 sound.
Hey, So i have on-board realtek HD audio card (6 jack) with my 5.1 system connected via 3 jacks (front , surround & sub). The problem is that i've just run the auto calibration thing with the microphone and it worked fine and calibrated all of my speakers, but now my subwoofer doesnt work with...
No Sound from speakers only from reflex subwoofer
Hi, I just upgraded my HP dv7-1135ea from Vista to Windows 7 RC and the speakers are not producing sound, only the reflex subwoofer at the base of the laptop is producing sound. Is there something I can do to get the speakers working? While installing Windows 7, the installation complained of...
