Windows 7: Audio Driver Problem
04 Aug 2013   #1
kjames05
windows 7
I've been trying to fix the audio driver on my custom build. The audio works fine for most programs, but for the Elgato Game Cap software I get no signal. When I go into the Device Manager under the sound, video and game controllers tab, 'VIA High Definition Audio' works fine but the 'High Definition Audio Device' has a caution sign and says the device cannot start. I've tried updating, uninstalling, reinstalling, disabling, downloading drivers from Realtek, but so far nothing has worked. I've used a couple of driver programs as well but those didn't work either.
Any help on the matter is greatly appreciated.
Particulars: Windows 7 Ultimate SP1, Intel i5 3570k cpu, Gigabyte GA-Z77 mobo.
04 Aug 2013   #2
fireberd
In most cases (all I've seen) if its just "High Definition Audio Device that is usually a generic Windows installed driver. What video do you have? With the i5, it has built in Intel HD Video and also HDMI Audio. You should also be showing Intel HDMI Audio in the Device Manager.
More PC Spec's are needed.
It sounds like the PC sound is working OK and the issue is with the Elgato software.
I have a GA Z77X UD5H motherboard (with RealTek audio).
04 Aug 2013   #3
kjames05
windows 7
Thanks for the reply. I used a driver program, Slim Drivers I think, and it solved the caution symbol. Well, actually it removed the 'High Definition Audio Device' driver and replaced it with 'Intel(R) Display Audio' (which works fine). However, still no resolve with the Elgato Software working.
I've used the Elgato Software on my laptop and it works as expected. Laptop also has the Intel Display Audio driver. So it's definitely an issue with my PC. Laptop has 7 Premium SP1, i5 2430m @ 2.4ghz
Basically the Elgato is a game capture device. I've got an HDMI cable going from my Xbox to the Elgato device, and then another HDMI cable from the device to my monitor. The passthrough works fine.
The video driver is Intel(R) HD Graphics 4000. The PC is connected to the monitor through a DVI cable
04 Aug 2013   #4
fireberd
I know nothing about that hook up. The gaming section of the forum may be a better place to get help with that.
The actual PC audio is working OK, its just this application.
Windows 7 audio driver problem
Today i installed Windows 7 Ultimate and all worked good with drivers exept sound, have old drivers on CD but this OS doesnt support that old drivers...checked this thread (have same problem) soundmax integrated driver and tryed to install that and same still problem Motherboard is : Asus...
ok hi, i have just purchased a PC which im running as a server, with server 2008 (windows 7) I have managed to find the drivers for the NIC, now all that i need are the audio drivers. I have the multimedia controller in device manager, and it finds no drivers online. I have downloaded...
Drivers
Realtek HD audio driver problem
Hi friends..:) Am using Windows 7 Ultimate 32 bit, I don know about my sound card, How can i find it? I have installed realtek r2.55, its features are really good..! Am thoroughly enjoying it.. but, i have a problem. If i listen to music more than 3 or 4 hours or watching one or two...
Drivers
Hi all, I have a BENQ Joybook S53, and after I installed W7 last night, the audio stopped working. It says that I have "no audio devices installed"... It also happened to me last time when I rebooted my XP, but after I downloaded the audio driver everything went well. However, this time, even...
Asus A8N-LA audio driver problem
Hey all...first post here. Seems like a great place, hope you guys can solve my problem. In searching for my missing driver, I came across this site, read the other threads, but nothing works. Here's the problem. I have an older pc that I just upgraded to Win 7 Ultimate 64bit. Everything...
Drivers
No Audio, Driver Problem
Hi, Recently I had a mishap with the Creative X-FI driver 7-30-2009 update, and I can no longer hear sound in Windows 7. As a result from this, most of my audio drivers/Creative X-Fi programs ended up deleted. At that point, I tried to uninstall my audio card from device manager and restart to get...
